Old 05-13-2008, 07:04 PM
zach zach is offline
Default Merc Opti Performance Report - 20 Master Angler
Not sure if anyone has noticed this yet, but it might prove helpful for some:
http://www.mercurymarine.com/look_de...optimaxProXS=8
Old 05-13-2008, 11:11 PM
Default Re: Merc Opti Performance Report - 20 Master Angler
5.5 mpg at 3000 rpm and 22 mph. That's very good!
Fr. Frank says:
Currently without a SeaCraft
Old 05-14-2008, 03:34 AM
I'm surprised that the motor is so slow on the hull.
Old 05-14-2008, 10:23 AM
I was thinking the same thing, I'm told The suzuki 140 will push it 40. I would have thought the Optimax could do better then that.
Old 05-14-2008, 10:32 AM
My 150merc from 1981 will do 41.4 with a dinged aluminum prop and your 130 yamaha is even faster with 2 people, full tank, will do 42.? with the stock aluminum prop.
Those numbers are kind of embarrassing . . . considering how much hype there is around the power of these Optimax's.
Man . . . my seafari which is heavier w/ chunky bottom paint will do 47+ mph turning the same prop and that motor is a 29year old non-oiler, non-fingerported, vertical reed, 200 which is supposedly only 160 - 165hp (prop) from the factory.
Old 05-14-2008, 04:15 PM
mnwnvc mnwnvc is offline
The review said max speed was 42.1 MPH at 5400 rpm, At 3000 rpm speed was 22.4 mph and fuel GPH was 4.1 and 5.5 MPG. At max speed the fuel consumption 14.2 GPH and 3 MPG. Thanks for posting the link.
Old 05-14-2008, 04:37 PM
dcobbett dcobbett is offline
I like the lower end numbers, but none of the high end numbers are any better than what I get on my 20 with a 130 Yamaha 2S and no effective tabs (not yet, anyway!).
Old 05-14-2008, 07:32 PM
I think their new "Master Angler" comes standard with a t-top, so add a couple mph to get a speed with no top.
Old 05-15-2008, 12:35 AM
I'm seeing a lot more speed as well, but don't forget that you, Strick and I are all running a bracket, which may be worth about 3 mph in top end speed. From what I've read, being able to run the motor in "cleaner" water and the ability to raise the bow with the rearward weight shift and reduce wetted surface may explain most of the performance improvement with a bracket.
Old 05-15-2008, 09:07 AM
JohnB JohnB is offline
My optimum cruise went up 3 mph, 24 to 27 and my top end went up 4, 41 to 45, using the same motor and prop, going to a bracket.
JohnB / 23' SeaCraft
