Old 05-30-2008, 08:35 PM
Bryan A. Bryan A. is offline
Default Re: Thru transom scuppers conversion from thru flo
BTW, xing or criss crossing scupper drain lines has been around for a long time and I believe it started in sail boats to drain the lee side of the cockpit which would be at or below the actual water line when the hull was healed.
Wouldn't that require water to run uphill??
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 05-31-2008, 12:19 AM
abl1111 abl1111 is offline
Aside from the Criss Cross idea; when you convert from thru floor scupper to thru transom, you gain a few vertical inches as to where the scupper exits the transom - right ?
But, you still need a product like the Rabuds or similar ?
I wish I had done this when I re-did my transom, but I had so much work on my plate, I let it go. Is it a be'atch of a job when all is together ? Again, I have a 23' Tsunami w/ an I/O - it's a little different.
There just is nothing good about the thru floor scuppers; it's to small to drain water quickly, it keeps the floor wet when weight is in the corner, and the brass tubes need replacing very so often.
I want 'em gone. But, only if it is a benefit to do so. Has anyone done a 23' ?
Old 05-31-2008, 12:28 AM
htillman htillman is offline
Use plastic drain tubes instead of metallic until you have time to convert. The plastic ones are available at Discount Marine. Most Seacrafts sold after 1976 used the plastic types.
Old 05-31-2008, 10:58 AM
dcobbett dcobbett is offline
abl1111,
The main reason I converted the scuppers on my project was that, as they were, they represented two uncontrolled holes through the bottom of the hull. I moore the boat and to my way of thinking, eliminating that potential disaster was a major benefit. I also plugged the fish box drain for the same reason, although the situation there is not as critical.
Regarding the crossing scupper drain piping, the lines are usually not laid flat or parallel to the water line; they slope down and generally back, often at a pretty steep angle (30^+/-).
