Old 11-15-2008, 06:24 PM
tthomp7205 tthomp7205 is offline
Default Hull weight of 1984 23' CC
Does anyone know the hull weight of a 1984 23'CC?
Thanks,
Tommy
Old 11-15-2008, 07:16 PM
BigLew BigLew is offline
Default Re: Hull weight of 1984 23' CC
Did you check this?
http://www.classicseacraft.com & look under specifications.
http://www.classicseacraft.com/SF23.htm
Plan accordingly!
Old 11-15-2008, 08:58 PM
I looked at those, but my boat holds 150 gal of fuel and those only hold 100 gals.
Someone told me it weighted 5800 lbs, which is way too heavy in my mind.
Tommy
Old 11-15-2008, 11:27 PM
peterb peterb is offline
IMO I would guess that all of the hulls weigh between 2,700 and 3,200 pounds.
Then you throw in the other stuff:
- Full tank of gas
- Engine(s)
- T-top
And calculate it accordingly
Peter
Old 11-15-2008, 11:34 PM
Tommy
1 gallon gas = 6 lbs. per gallon
150 X 6 = 900 lbs. of gas.....
just my 2 cents worth.
See ya, Ken
Old 11-16-2008, 12:12 AM
The hull is roughly 2700 lbs (70 gallon tank or 200 gal empty tank). Now add your motor, plus your gas, plus your gear, ice and beer, plus your trailer. And that probably puts you at about 5500-5800lbs lbs that you'll be trying to stop going down a steep grade... You can take it to a local dump or truck-stop and have them weigh it if you really want to know what your towing... If your hull weighs 5800 lbs its not a 23' SeaCraft...
Old 11-16-2008, 06:20 AM
Thanks everyone for the information. I'm taking it to a scale this comming week.
Tommy
Old 11-16-2008, 09:30 PM
gss036 gss036 is offline
The net hull weight on my 1989 23WA is listed as 3040 lbs. and has a 115 gallon tank, I know that because I was looking at it yesterday and it is stamped into the tank.
Gary
