Old 11-25-2008, 11:19 PM
Default Re: when do you pull your boat for the season ?
My seafari is all buttoned up and ready for snow.
Old 11-26-2008, 12:04 PM
Talk about rubbin' it in... [img]/forum/images/graemlins/tongue.gif[/img]
Go easy on our northern brethren..
They can't help the effects of
global warming
See ya, Ken
Ken-I think those previous posts are going to leave a mark
Old 11-26-2008, 02:56 PM
bigeasy1 bigeasy1 is offline
I just read that Barack Obama is signing a new law into effect that will require all boats to be off the water for the fall and winter months,It will be effective from November 1 to April 1.
So there,take that, all you southern,and California guys.no more last laughs for you.
All this,just for a boat ride
Old 11-27-2008, 12:22 PM
Rainmaker Rainmaker is offline
In that case, I will need to leave a boat in the Bahamas in order to continue to get my fix.....
Actually, while there is not really a time when I stop fishing and winterize the boat I do have a certain drop off in the use of the boat as Fall and Winter near. I think it is more because I neglect many items through the summer and need to get back on them. It also has to do with the fishery that exists in the Summer vs the Fall and winter. I am not a fan of catching billfish, or Kingfish and with the changing weather those seem to be the active targets.
I will get out on occaision all year, but I basically throttle back late in August when I return from my annual Bahamas run. I will get back to a very active boating and fishing routine again late April or May.
Old 12-01-2008, 01:51 AM
seafari25 seafari25 is offline
Location: Eastern Canada...Wallace, Nova Scotia every chance I get
Hey Scrapper,
If you have an outboard, you can leave your boat in until freeze up. At the end of the day tilt her up to drain the water out of the head and put her back in so the hub is just under the surface. If you leave the motor out of the water you run the risk of water freezing and cracking the hub. If it's an inboard or I\O you can usually get away with putting a light bulb in the engine box over night but I don't recommend that. Especially if you have tranny or p.s. coolers. We sometimes leave the aluminum and steel boats in till we cant break the ice anymore. As long as you don't get more than 3" of ice over night, you're in good shape.
Just the Canadian boys 2 cents
