Old 04-29-2009, 12:01 AM
contylhil contylhil is offline
Default 1984 23 O/B Open - fuel tank capacity?
Hello all, I am new to the group, have had my Seacraft for 10 years now. I have appreciated it immensely. I knew I was buying a good hull at the time, but really had no idea of the quality, design and ride I had lucked into.
In any event, here's my question: I was told my fuel tank is 90 gallons (almost certain it is original), and that seems pretty close to my calculations. Can that right? The specs on this site say 100 gallons??
Old 04-29-2009, 06:53 PM
Vaguada Vaguada is offline
Default Re: 1984 23 O/B Open - fuel tank capacity?
my 1985 23cc had a 140 gallons tank.
Old 04-30-2009, 12:17 AM
My 82 23' CC had a 110 gallon tank. Said so right on the metal plaque.
Fr. Frank says:
Currently without a SeaCraft
Old 04-30-2009, 02:24 AM
There you have it, all cleared up, glad we could help
Old 04-30-2009, 06:46 AM
If you can get at it....
(L*W*H)/231 = Gallons
1974 23SF
Old 04-30-2009, 02:17 PM
gss036 gss036 is offline
My 1989 23WA had a 115 gallon tank. Replacing w/75 gallon.
I could not get the 99 inch long tank out in 1 piece.
Gary
Old 04-30-2009, 09:21 PM
BigLew BigLew is offline
My '85 Scepter's tank is stamped 144 gal. I say it is a LOFF; lol.
Plan accordingly!
Old 05-01-2009, 01:00 PM
SECF3114M73J SECF3114M73J is offline
My'73 was listed as 100 gal. When I had a new tank made they said 100 capacity, 95 gal. usable.
Old 05-01-2009, 05:54 PM
Thank you all! That did clear it up. Somewhere between 90-144 gallons. I'll check it again to see what numbers I can read on the tank. (I have easy access to about 3 square inches of the tank) Or maybe I will just have to run it dry sometime. Seatow loves that.
Old 05-01-2009, 09:54 PM
sasquatch, don't know if I would do that. When you run with real low fuel you stand the chance of all the junk on the bottom of the tank gets sloshed around and the junk ends up in you fuel filter. I did that on the 15th and ended up with a clogged filter and primer bulb sucked flat. Thanks goodness for a kicker.
Gary
