Old 08-10-2009, 07:10 PM
cobiawayne cobiawayne is offline
Default stern heavy
got a 71 20 ft cc seacraft, closed in transom and installed a livewell in transom,26 inch stainless marine bracket.I have played with some weight up front and as long as I,m the only one in it its great,but when I have some else with me I have to run really trimmed down.I,m running a laser11 19stainless prop.I use the boat mostly for offshore fishing.I,m wondering if anyone has experience with this setup and if I need to go with trim tabs or smart tabs or just one of those doel fins.Oh yeah its a 97 merc 200 top speed 53 mph gps.Got a great deal on the motor,can,t afford to change motors.Any help would be greatly appreciated.Thanks
1971 seacraft 20 1976 seacraft ma
Old 08-10-2009, 08:28 PM
vcs vcs is offline
Default Re: stern heavy
Does the boat porpoise if you don't trim down?
Old 08-10-2009, 09:28 PM
Yes especially if my livewell is full and i,ve got a passenger behind the console with me
Old 08-10-2009, 09:45 PM
bridgeman bridgeman is offline
outboard most likely is hung too high
Old 08-10-2009, 10:08 PM
Yep just went out and measured and best i can tell while fighting off a swarm of sqeeters is it looks like cav plate is 5 inches above keel
Old 08-10-2009, 10:09 PM
vcs vcs is offline
when I put the bracket on my 18ft it did the same, I installed a doelfin and that fixed the problem I would suggest you try that they are inexpensive and do work.
Tony
Old 08-10-2009, 10:18 PM
BigLew BigLew is offline
Don't forget to drop the motor down on its mounting bracket, if possible!
Plan accordingly!
Old 08-10-2009, 11:03 PM
vcs vcs is offline
here is a previous post about engine mounting here is the post
Get a straight edge and bring the motor to neutral trim, see where the cavatation plate lines up should 1 to 1 11/2" above the hull bottom. Props with long blades or alot of cup can go higher
Old 08-11-2009, 06:21 AM
i,ll start experimenting with it and post results i have to feather the throttle now to keep engine from gettin swamped on stopping.
Old 08-11-2009, 12:59 PM
I think this is my post and thats only for transom mounted engines - the set back from the bracket changes everything. Usually the issue is either motor too low or too much weight in the stern or both. If its not cavatating then its not too high.
