Old 08-26-2009, 09:47 PM
stumpie2 stumpie2 is offline
Default 25 seafari questions
as i mentioned before, im in the process of repowering my 25 seafari with a bracket and an outboard.... i have a question that has me scratching my head... per the specs section here on csc the 25 seafari only weighs 3000 lbs without the engine (dry)... something about that doesnt seem right. compared to a 24 albe at approx.5000 lbs. am i missing something or is this correct... maybe i should tow it to the salvage yard a use there scales to get an approx. weight?
http://i729.photobucket.com/albums/w...ictures007.jpg
I DONT KNOW, BUT I'LL GIV'ER HELL TRYIN!!!
Old 08-26-2009, 10:05 PM
htillman htillman is offline
Default Re: 25 seafari questions
I weighed my 23 to check to the weight during and after the rebuild. It was fine and the weight was fairly per the specs.
Old 08-26-2009, 11:00 PM
3rdday 3rdday is offline
To the scales, so that yo have a KNOWING!
If you are all stock and significanlty over the specs, start looking for water in stringers, decks, transom and foam. If none found there, There is a chance the polyester resin which is what was used back then and the only technology avaible, may have absorbed water. no big deal unless you get osmotic blistering, but I would not expect that unnless the boat is kept in the water.
Old 08-27-2009, 12:00 AM
no water logged structure in the boat... new stringers and bulkheads in '06 and trailer and dry stored since... the 3000 lbs. just seemed a little light especially since many sc owners are running high horsepower engine(s) compared to the light weight of the boats... a buddy of mine runs a '03 25' trophy, listed 4250lbs. with a 225 opti on a bracket and ive seen 43mph gps at 5500rpm. so if the 25 seafari is only 3000 it ought to fly with a 250 merc efi... i understand the deadrise of the hull may factor into the equation, but i cant see where i will need anymore hp unless im overlooking something... any comments?
Old 08-27-2009, 07:11 AM
Default Re: 25 seafari questions - weight calculations
I just looked at the BUC website and the 2003 2509 WA Trophy OB model is listed as 4400 lbs net weight. The net weight of a boat is based upon buoyancy, and is the weight of the hull, plus power, fuel, persons & gear. It is also called displacement.
For example, my 20' Seafari has a listed hull weight of 1800 lbs. My motor weighs 375 lbs, I carry 28 gallons fuel, and I have a max capacity of 9 persons, or 1455 lbs persons and gear. If we go with the max of 1455, the equation looks like this:
Hull - 1800 lbs
Fuel - 168 lbs
Motor - 375 lbs
Persons/gear- 1455 lbs
Net Weight or Displacement - 3798 lbs
For your 25' Seafari: Hull - 3000 lbs, 105 g. Fuel - 630 lbs, 7.4 L sterndrive(1982 weight w/ TRS) - 1244 lbs, Max capacity persons & gear - 1619 lbs = 6493 lbs net weight.
So an "apples to apples" comparison using your examples is:
2509 Bayliner Trophy = 4400 lbs net weight or displacement
25' SeaCraft Seafari = 6493 lbs net weight or displacement
Fr. Frank says:
Currently without a SeaCraft
Old 08-27-2009, 08:56 AM
Ryank Ryank is offline
We salvaged and scrapped a 25 fly bridge that weighed 2800 w/out engine or fuel, it took the D6 dozer approx 20 seconds to make it look like a flat pancake that couldn't have weighed more then 500lbs lol. It was amazing to watch.
Seacraft's for life !!!
Old 08-27-2009, 11:56 PM
seafari25 seafari25 is offline
Location: Eastern Canada...Wallace, Nova Scotia every chance I get
Hull - 1800 lbs
Fuel - 168 lbs
Motor - 375 lbs
Fr. Frank
In no way am I opposing what you are saying. In fact, my signature should read "wisdom is learning from Fr. Frank" by now but this topic is of particular interest to me. Not just because we're talking about my favorite 25' boat but also because I'm in the scale business.
On the Railroad, we refer to net weight as the weight of product in a rail car not including the light weight. The 2 added toghther would equal the gross weight.
In my mind, displacement should be the gross weight.
Are the terms different on the water
Brandon
BTW Nuthinfancy I`ve never had the opportunity to check the dry weight of ours but I think Fr. Frank`s right on at around 6 to 7000 lbs displacement according to the guy that stores our boat for the winter (although he hasn`t actually weighed it). I guess he just has an idea compared to other boats he stores.
Old 08-28-2009, 01:10 AM
I TOTALLY RESPECT FR. FRANKS INSIGHT BUT I WISH THERE WAS SOMETHING TO COMPARE APPLES AND APPLES TO.. SUCH AS ANOTHER 25' SC TO COMPARE TO OR A BOAT OF SIMILIAR DESIGN. IE SEABIRD, ANACAPRI, ALBE... O I FORGOT THERES NUTHIN LIKE A SEACRAFT... BECAUSE IM TRYING TO AVIOD WEIGHT ISSUES AND REALLY DONT WANT TWINS= NEED MORE FUEL AND MAINT. AND THE BIG 4 STROKES ARE SO LAZY AND HEAVY
Old 08-28-2009, 01:45 AM
Sounds light to me also, I thought my 23 Sceptre was 3540 dry. Check a newer 25 CC and see what it lists at ??
Old 08-28-2009, 12:04 PM
THE NEW SEACRAFT 23 CC HULL IS APPROX. 4200 LBS AND THE 26 CC HULL IS APPROX IS 4600 LBS. I THINK THEY WEIGHED THESE THINGS DIFFRENT BACK IN THE DAY... MAYBE NO LINER OR CAP JUST THE EMPTY HULL...
