Old 09-19-2009, 01:04 PM
Default Bilge pump outfall location??
I'm putting a new 1500 GPH Rule bilge pump in my boat to compliment my little 500 gph that currently lives in the bowels of my boat.
I'm running a 1-1/8" line to the outfall.
Question: I want to exit the line on the starboard side, so I can see/monitor it. How high up on the side / freeboard should i exit it?? Too high and it reduces the flow capability due to head loss, too low and it come back in the boat.
Before I go drilling holes in my boat, I wanted to get some opinions and experiences from everyone.
Proposed location on attached picture. What do you think?
Thanks,
Jim
Old 09-19-2009, 02:50 PM
stumpie2 stumpie2 is offline
Default Re: Bilge pump outfall location??
the ones on my 25 are about where you projected area is. try to find pics of other 23s a go from there
http://i729.photobucket.com/albums/w...ictures007.jpg
I DONT KNOW, BUT I'LL GIV'ER HELL TRYIN!!!
Old 09-19-2009, 07:28 PM
bigeasy1 bigeasy1 is offline
On my 23 Tsunami,I placed the bilge pump thru hulls in just about the same location,as you are thinking of.They work very well in that spot.
I have two pumps,(1500 & 2000 gph)with a thru hull on both the port and starboard sides.
All this,just for a boat ride
Old 09-21-2009, 11:50 PM
3rdday 3rdday is offline
I have a 1 way valve on mine and its just above the waterline
Old 09-22-2009, 12:52 AM
That idea scares me. Completely dependant on the mech. working of the check valve? Doesn't seem very "fail safe".
Is there more to this application?
Old 09-22-2009, 01:38 AM
riptide riptide is offline
Your in the right spot.
Mine has 1-2000gph & 2-750s
77 Sceptre 250 Suzuki
Old 09-22-2009, 08:05 AM
Mine was put back where originally located with a second one added.
1 2000gph
1 500gph auto
1974 23SF
Old 09-27-2009, 04:58 PM
Thanks for the advise guys! Got it in today. Also I documented some measurements at the same time.
Old 09-29-2009, 10:23 PM
its just a suggestion but if i were you id get a little more pumpage in there. i like the idea of the automatic ones. ive got an 1100 and a 2000 in my 20sf. 1100 on a float switch and 2000 on manual switch.
