Old 11-08-2009, 01:59 PM
Daltonmarineinc Daltonmarineinc is offline
Default T top help on 23cc
im haveing a problem with my top, its pulling through the deck.when i started this project i new this problem would come soon.the top mounts on the outside of the fule tank and there is a wall serounding the tank.no way to through bolt it unless i cut plates in the deck on each side.wondering if anybody has run into the same problem. thanks
Old 11-08-2009, 06:29 PM
Default Re: T top help on 23cc
You could pull the legs up and install toggle bolts in there, then you wouldn't have plates there.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 11-09-2009, 07:30 PM
Trey1096 Trey1096 is offline
You could drill an oversized hole, like 1/2" diameter. Then wax a 1/4" bolt, put a nut on it, and epoxy it into the hole. After the epoxy sets up, unscrew the bolt and you’ve got threaded epoxy and an embedded nut that you can run a machine screw into.
You may want to gouge out some of the coring so the thickened epoxy would have a wider section between the skins to help prevent pull out.
Does Daltonmarineinc mean like Dalton Marine between Acworth & Woodstock?
Trey
Trey
'64 13' AeroCraft, 15 Rude
'74 23 SeaCraft, 225 Opti
'84 18' Winner, 150 Merc
The bitterness of poor quality lingers long after the sweetness of low cost.
Old 11-10-2009, 12:26 AM
i have strips of 1 inch poly board under the top.i cant find toggle bolts long enough to go through the deck and the poly.the epxoy is a good idea,if i can find something that will stick to it.thanx
tray no i have a small marine supply shop in homestead boats and trailer repair
Old 11-10-2009, 01:12 PM
Look in the Lewis Marine Supply catalog, page 391 Fig # 9124
1974 40' Eagle
www.parkeryacht.com
Old 11-11-2009, 02:15 AM
Several boats ago this it how I anchored the CC to the deck. The T-top was then anchored to the cc and deck with aluminum backing plates. I call it the ultimate consel set up. The cc acts as the base for the t-top and if the base is strong then nothing will pull apart. Notice the Variable degree deadrise hull
Old 11-12-2009, 10:52 AM
Now THAT is one hell of a deep "V"......
Old 11-12-2009, 01:41 PM
Default Re: T top help on 23 cc
I used similar L-bracket scheme to mount my galley seat, except I used oversized thickened epoxy-filled holes in deck instead of the below-deck L-brackets. Seating area of the original Seafari deck has ~3/4" plywood core instead of 1/2" balsa core; I drilled 1/2" hole thru deck but NOT thru bottom layer of glass, and then filled with epoxy. I then drilled and tapped the epoxy for 1/4-20 machine screws, which hold better than tapping screws. Toughest test to date has been 185# guy in seat in 5-6'seas; seems solid so far.
Old 11-15-2009, 03:56 PM
BigLew BigLew is offline
Stick,
You are a work of continual amazement. What's it like to be such a fart smucker!
Plan accordingly!
Old 11-20-2009, 03:12 PM
thanks guys. i used L brackets on the cc then got longer toggles and whent through the deck.worked perfect
