Made the switch from plywood... 1.5" penske for the transom and corecell for the deck. Got it tabbed in yesterday, its rock solid already.
Poured foam in the stringers, and got worse at it on each one. How does that even happen? I gotta say that is amazing stuff to work with. First pour ![]() ![]() ![]() Picked this bad boy up from home depot, its like a jet engine and gets the garage toasty. ![]() ![]() ![]() ![]()
50 Ton, '72 SC 20 |
Looking at these pictures I am feeling encouraged. I will own my dad's '72 20' before too long and when I do I'll have to tear out the floor. Fortunately it's simply a matter of removing the rivets behind the rub rail and lifting the innards from the hull. I don't have my '73 Shovelhead to tear apart any more, ride a BMW now. So I'm looking forward to getting personal with the boat. Looking forward to seeing the end results, Yours and Mine.
Sandhog
"When the resolution of enslaving America was formed in Great Britain, the British Parliament was advised by an artful man,- who was governor of Pennsylvania, to disarm the people; that it was the best and most effectual way to enslave them; but that they should not do it openly, but weaken them, and let them sink gradually, by totally disusing and neglecting the militia." --George Mason, speech in the Virginia Ratifying Convention, 1788 |
Grinding with those 36g pads is so easy, its practically a roto-tiller- just gotta watch touching the foam... At least it doesn't make any dust though.
![]() ![]() ![]() Rough cut out on the transom ![]() ![]() Layer of glass sealing in foam, 1.5" foam risers, matt draped over and glassed. ![]() ![]() First layer of glass on transom ![]()
50 Ton, '72 SC 20 |
After raising the stringers and laying out the corecell, its gonna be about 17 or 18 inches from the deck to top of the gunnel (at lowest part close to transom). This seems super low standing on the boat now... I know its not a tall boat but are those measurements regular on other 20s?
50 Ton, '72 SC 20 |
Your restoration is coming along nicely! Keep up the good work. As far as the freeboard goes, the 20 doesn't have much to begin with and by raising the height of the stringers you will decrease it even further. 17" sounds about right though mine may be less than that.
Will |
update... made a dolly to roll in and out of the garage- works like a charm. 3 sheets of corecell for the floor, with woven- one layer from each side, overlapping in the middle. its strong but i haven't convinced myself not to add one layer of 1708. other than that fitting the tank underneath and sanding...
**if anyone has a heated garage bay or anything let me know, i'm sick of being outdoors/ the cold weather is slowing progress. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
50 Ton, '72 SC 20 |
Boat is looking great
I like your roller base. I made similar base but the rollers must be too small because it is not easy to move. What size rollers did you use
Thank you ed |
What kind of resin are you using? It's very red.
Dave
