I did hear that they had worked most of the issues out boy 03-04 I guess I am still just gun shy,
One thing was in referencing props, I am running a 4 blade 18 pitch. I have never topped out my RPMs but feel it would be close to 57-5800. I wonder if I am over propped and hurting the motor?? ![]()
Seacraft's for life !!! |
Did you just reference the late great Lowell George and the B 52`s in the same post? Oh the horror. ![]() I got to see the fat man melt in `77 @ UVA. What a tasty player he was. Awesome slide. He and J Geils got no respect from the scribes. Abba is in the hall of fame and J Geils and Little Feet are not? Full House is a seminal live album. As is Waiting For Columbus. I think 03 is either the first good year or the last bad year of the dreaded Opti Bombs. Cheers, GFS |
He is correct about the years - the earlier ones earned the Opti - Bomb name. On a Seavette though a single 225 ain't gonna cut it, if you need help with the existing motors let me know I have a good merc guy that works pretty cheap and can get you a 25% break on parts through somebody else- he can ship powerheads back and forth - you would need somebody to get them off though but they would be turn key when returned. Thats what I did and saved 1000
Ryan & Dixon, Thanks for the follow up. Opti I was looking at was a 2001 so I'll stick with the old power for now (assuming I can get'em running right).
Is a shot of WD-40 in each cyl before trying to turn over ok? Sandy, Feats never fail me. Lowell was brilliant even well-baked. I never saw him live. But drummer Ritchie Hayward went to my high school in Iowa. I've seen them numerous times since the fat man passed, and they have always exceeded expectation. Fun band. Waiting For Columbus is definitely a "desert island disc," IMHO, perhaps the most perfect road trip record, evah ![]()
Gillie, I used seafoam deep creep in my inboard..removed spark plugs, sprayed and let sit..I remember as a kid...spraying WD40 on my minibike wheel bearings.they stopped sweakin...I think they lasted about a week...WD40 did what it was intended to do..and the bearings were very clean minus grease!
I would use it on exterior though..keep those blocks protected I dont have enough knowledge to know about using WD40 in each cylinder though..I wouldn't do it! -Fred
I have always used WD-40 in the cylinders and on the outside of everything I've winterized. I could be wrong but oil based and water displacing? Can't ask for much more.
It has always worked for me. |
WD40 is not an oil - maybe just put some outboard oil in a spray bottle, if they will start the WD40 is OK but as stated it will remove oil as well, hell I used on my hands to remove exopy stick on my hands the other day.
To save me the trouble of looking it up but whats on it now?
Thanks guys, because I'm just seeing if it will turn over, I'll stick with some 2-s oil in a spray bottle.
Dixon, If you were asking what motors were on the Seavette, they are '83 2.4L Merc 200's with wh-15 carbs and are allegedly tuned to 225hp, whatever that entails. They have old style heads but horizontal reeds which apparently started in '83. Presume they have finger ports but have not opened them up. looks like I'll be removing them soon... more on that in the repairs and mods forum. [img]/forum/images/graemlins/tongue.gif[/img]
So they don't run or don't turn over or just sit there LOL
those are pretty popular motors and a good fit, either those or 2.5 carbed, you might find a couple drop on powerheads on Scream & Fly that would make life easier and cheaper. They seem to go for like 2500 fresh, I looked into that myself - cranks are the issue, good your golden - not gets way more expensive. They are good bullet proof motors with lots of parts avaiable cheap. Another big question is if you can get the PH's off the mids, if you can PH's are cheap. I learned alot about parts avaiablity for 2.5's when I needed too, parts are cheap labor is not.
I expect they will run but I'm going through the starters, solenoids and wiring before giving them them a whirl. Its been sitting a long time. Lots of corrosion.
I got some brush kits Saturday but was having too much fun looking in the hull to do anything. The hull is gonna need a new transom. Definitely been rode hard and put away wet.
