Old 06-20-2010, 08:54 PM
2182 2182 is offline
Default custom wooden boat...
...to complement my seacraft. came across a custom built wooden boat that im considering buying. its 8 years old, marine plywood (painted), white oak stringers, mahogany deck and engine box. could use a bit of cleaning up but its built soundly and rot free. the owner has all the cleats, lights, etc, it has a new rudder and prop, no engine, no transmission. i have very little experience w/ inboard engines. my question to you guys is how much will i be looking at for a motor and transmission? the boat is about 17 feet. also, how big (ballpark) of a motor does it need? lastly, considering i wont be using it much, is it a bad idea to get a used inboard? old, unreliable outboards are a nightmare (as we all know), are inboards any different? i know i can search the web and find some info but you guys are so knowledgable, it never hurts to ask. thanks in advance.
Old 06-20-2010, 10:09 PM
Default Re: custom wooden boat...
Got a picture?
I assume straight inboard?
How many feet forward is the stuffing box?
When you say it is painted, is it possibly skim coated in resin and glass then painted?
I would think a boat that size would have a tendency to be wet and pound with a inboard to start so I would think a 4.3 might be the best compromise.
Old 06-20-2010, 10:46 PM
MasterBaiter MasterBaiter is offline
If you could post a picture it would help.
What is the layout - center console? runabout?
What is the shape of the hull? What is the weight of the boat?
Old 06-21-2010, 09:03 AM
boat does not appear to be skim coated, as i can see the "filler discs?" in the plywood through the paint. i can also make out putty/bondo circles where there are screws. its light, i bent my knees and gave a lift in the bow and raised it up a few inches. "filler box" is motor enclosure i assume, farther forward than a lot ive seen. has old school bench seat in front, motor box directly behind (right in middle of boat), then another bench seat in the way back. its a simple runabout. hull is similar to an old chriscraft, not much deadrise, wide bow, nice lines where transom meets gunnels. i believe it is designed for a straight inboard, just has two exhaust ports cut into transom, like i said im no genius when it comes to motors. i got a few pics on my phone, i guess nows as good a time as ever to try and learn how to post them. thanks
Old 06-21-2010, 09:21 AM
attempt #1 at picture [image]http://http://i1043.photobucket.com/albums/b432/justinnat1/woodboat2.jpg?t=1277123697[/image]
Old 06-21-2010, 09:39 AM
wow, im so surprised that didnt work.
Old 06-21-2010, 09:41 AM
Default Re: custom wooden boat... *DELETED*
Post deleted by 224466
Old 06-21-2010, 09:43 AM
i know pictures would help but i dont see that happening this morning. if i keep trying my computer is heading out the window. ill try again this evening.
Old 06-21-2010, 09:56 AM
[image]http://[/image]
Old 06-21-2010, 09:58 AM
i cant beleive this worked. im 28 years old so i really have no excuse for hating computers but... [image]http://[/image]
