Starting to redo a 69 Formula Thunderbird. The deck is pretty well mush. I was thinking of building a cored deck using fiberglass and polystyrene foam planking. Think from Home Depot. Any input would be appreciated. I know it's not a Seacraft but still looks like it could be an addition the the toys.
Thanks Bob |
I would consider a material designed for marine applications, like Coosa Composites. We use a ton of this at Proline...
i plan on using coosa for the transom in my 23. plan on using plywood for the floor because it will hold screws for the t-top. how does pro-line secure tops ??
Why would you usecoosa for the transom and not just use wood? Mine is solid wood and glass. At least 5 inch on the transom
1974 23 SF - "Likes It Rough" http://www.classicseacraft.com/forum...rt=&PHPSESSID= |
my reason behind it is, its lighter and since SC's are already stern heavy i figured it could use all the help it can get. thats the other reason for the wood floor. keeping the weight forward. again because it will hold the screws better than the coosa.
Blue,
As long as the Coosa coring is pre-drilled, we have no problems getting screws to bite in Coosa... ![]() |
Couple of issues / problems with pink/blue polystyrene basement insulation board. Polystyrene foam melts with polyester resin and will not even bond well with epoxy. I made a few sample boards and it worked "ok" if you cut it into 6" x 6" squares, but laminate didn't last long when I jumped up and down on it. The core is really too soft . . . 1/2" core cell, pesnske, coosa or marine ply are much much better choices . . . 1/2" marine ply and polyester resin is the least expensive route and arguably the strongest most durable laminate.
I used a material called penske board. Strong, light and does not absorb water.
Adam
1975 Seacraft 18SF w/2004 150hp Johnson 2-stroke on a 26" bracket |
