I used Teak Decking Systems Epoxy and seam caulk. I removed any soft core from the old deck, epoxied Joubert Marine Okume
13 layer Plywood then covered with 1708 and or 1808 biaxial glass with epoxy then glued the teak down with the Teak Decking systems epoxy, no screws, concrete blocks and buckets of water for clamps, worked like a dream. The teak was glued together 3 strips wide per segment and layed down as segments.The outside border pieces are strip laminated and were bent and glued around a form same as the rub rail. Feel free to call me at any time for anything about the boat 508-627-8941 |
Hard top came from J&J Marine Fabricating in Somerset Mass
Jeff Botello is a good friend of mine.Anything I needed in Stainless they made for me or Stainless Marine in Florida did. |
Here you go,you got to have one on this page, just in case folks are to lazy to click on the link. Very Very Nice. ![]()
Beautiful!!!!!
Now can you post some stats? What does the boat (or should I say artwork) weigh? How about fuel economy? Cruise and top end? |
Beautiful deck. Beautiful boat. Beautiful fuel economy I'm sure too. Keep a bottle of laundry detergent for diesel staining. Keep a wet deck fishing & fueling. Sharpening hooks is now a bigger nono. Nothing beats a teak deck for nonskid.
So I should plan on more than one evening- right? I have done teak over marine ply In Boat life and wanted to kill myself. West also has a brochure showing teak to epoxy to original glass with screws and washers between seams till cured and then caulking with West and black filler. Can be very light weight. Thinking of this for my 20 instead of deck replacement. With the price of teak it may be mahog.
M |
Tom Thanks for the offer of a phone call- will do when I start.
M |
Deju Vu we just left MV and think I saw your boat pull into Menemsha from the Lobsterville jetty. Was that you?
M |
Beautiful boat. Looks like you finished her just in time for the Derby.
great job
what do you have in it for power |
