Old 10-25-2010, 07:56 PM
Default Re: damp feet in an 18
Marelon to the main stage. Bronze, you`re on standby. Scupper dances are now two for one. Don`t forget your hard working bartenders and waitresses.
Flex lines. No prob on slackers. Pull stern boxes and measure starboard deck drain Barbie {its stripper name} to port scupper and vice versa. That`s how it`s plumbed. Double clamps.
The idea is that when standing in a corner, the water won`t ingress up hill across the transom.
Cheers,
GFS
Old 10-25-2010, 09:27 PM
redsonfly redsonfly is offline
Between Barbie and Bronze, I think this will work! The single hose eliminates all possibility of leakage below decks. I was concerned of the crossover, where one hose goes over the other, but it'll work no problem. i will support the hoses in the expanse below decks, no wiggling permitted here!
Thank you GFSM!
Old 10-25-2010, 11:54 PM
CaptBoland CaptBoland is offline
I've had the same problem in my 20ft. The ball scuppers work the best.
Old 10-26-2010, 09:06 AM
Thank you GFSM!
Not my idea. Thank the genius that is Carl Moesly. Check out moeslyseacraft.com
Stainless scuppers are really pretty.
Cheers,
GFS
