Old 11-30-2010, 11:26 PM
basswacker basswacker is offline
Default Taking off outdrive
Is it necessary to take off your outdrive and bring it inside for the winter when winterizing your motor? What are the benifits? It is a bravo one outdrive.
Thanks
Mmfishinglures.com
1976 23' Scepter
Lift weights get dates
Old 12-01-2010, 12:30 AM
Default Re: Taking off outdrive
Thanks
No. it is not necessary. leave the drive in the fully down position when it's in the place where it will stay, and that allows the water to drain out fully.
Fr. Frank says:
Currently without a SeaCraft
Old 12-01-2010, 01:40 AM
floorboy floorboy is offline
If it is going to freeze where you are it is a goog idea to change, or at least check the oil in the drive to make sure no water has gotten into the drive that may cause it to crack when it freezes.
Old 12-01-2010, 08:32 AM
Good advice.
Fr. Frank says:
Old 12-01-2010, 11:21 AM
pelican pelican is offline
Thanks
the drive should be removed and serviced every season.the splines on the input shaft need to be lubed with a "spline" lube-to avoid wear and siezing of the shaft in the coupler-also,the older drives,these have grease fittngs on the u-joints-only way they can be lubed is by removing the drive.
while the drive is off,everything can be inspected-gimbal bearing,shift cable and drive shaft bellows...trust me,pull that drive once a season !
reinstall it,after servicing it-no need to store it inside...
also,if the bellows are more than 5 seasons old,i recomend you replace them...
Old 12-01-2010, 02:17 PM
lost2a6 lost2a6 is offline
I agree with everything that pelican stated. And let me also add that if your prop has the rubber hub, then it wouldn't be a bad idea to store the prop inside when the outside temps gets below freezing for an extended period of time.
Steve B
1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH!
1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop
Old 12-01-2010, 07:57 PM
no need to pull the wheel if it has a rubber hub-freezing temps will never damage it...age and impact will tear it up,cold weather isn't a factor...just be sure to pull the wheel once a season-lube splines and rinstall
side note:
use no grease with mettalic compounds-especially "never sieze" you can create a galvanic reaction...
Old 12-01-2010, 11:03 PM
side note:
Not what my prop guy says. http://www.southeasternprop.com/index.htm He said that some times once the rubber shrinks due to the cold, that it will not expand back to its original diameter therefore resulting in a spun hub. I can't prove if he's right or wrong being as it seldom stays below freezing very long down here. Anyone want to put their prop in the freezer for several days to test his theory?
Steve B
Old 12-01-2010, 11:47 PM
side note:
depends on the chemical properties of the rubber in the hub. Some are affected by cooling and heating. Most modern two-piece hub designs are not, however. So Flo-Torq and similar hubs are safe in the cold.
Fr. Frank says:
Old 12-02-2010, 10:41 AM
it gets prtty cold in new jersey...last year we had record snow fall...
never have i had a client's prop "spin a hub" due to the prop being exposed to cold weather...there's 1000's of outboard powered boats in my area-same boats sit all winter with their wheels on-my own rig included,i've yet to see or hear of anyone else experiencing any problems...
