Old 03-31-2011, 09:23 PM
basswacker basswacker is offline
Default Original gas tank
How can i tell if my gas tank is original? also how thick is the transom on a 23 sceptre?
Mmfishinglures.com
1976 23' Scepter
Lift weights get dates
Old 03-31-2011, 09:55 PM
Default Re: Original gas tank
Every aluminum or SST underfloor fuel tank i've every seen has a mfg label on it. check yours out carefully, i'll bet there is one on it somewhere. It will have the date of mfg.
Would look something like this:
Old 03-31-2011, 10:39 PM
if it is not on top where is the next best place to look?
Mmfishinglures.com
1976 23' Scepter
Old 03-31-2011, 10:44 PM
That looks familiar.....
See ya, Ken
Old 03-31-2011, 10:55 PM
htillman htillman is offline
The transom wood is 1 1/2". Probably used 2 pieces of 3/4" plywood glassed together. I replaced mine with 1 1/2" Coosa board. Worked great.
Old 04-01-2011, 09:55 AM
Wildman Wildman is offline
If you dont see a tag on the tank, pull it.
If you dont see any corosion, pull it.
If you have the boat half torn up, pull it.
Its better knowing now, than the first time your 2+ miles off shore after just filling up and your bilge pump starts pumping fuel out of the bilge.
