My question is, if I am installing a 30in. bracket on the back of my 23ft Walkaround, should I raise my motor hight from the original?
How much should it be raised? Thanks, Big Mike
www.bigmikeslures.com |
I think the convention is about 1 inch up or every foot of setback. I imagine that will vary depending on bracket flotation and motor weight. With the walk-around you have a little more weight forward so 2.5 to 3 inches probably get you where you want to be.
Maybe Hermco can give you a more realistic number. Post some pics, ain't seen many of those... ![]()
![]() Quote:
![]() Quote:
The bracket will fix that I hope ![]() Big Mike
![]() Quote:
Does yours have any weightg in the transom? Big Mike
Mike,
I don't think the Seafari 20 has nearly as much weight up forward as the 23WA. The bunks should be about the same weight as the fwd casting deck and fishbox on the CC models, and the cabin top is relatively thin glass (about 1/8") with no core in it. The Seafari 20 cap we got for Skip & Carla's 21 is easily picked up by 2 guys; I'd guess it weighs maybe 50 lbs with no windshield on it. I've never heard of any ballast weights being used in the Seafari 20 like folks have found on the 23 Sceptre/Tsunami's. I believe the later Sceptre's (and probably the WA's) also used plywood cores in the decks instead of the balsa core used by Potter, which would add some weight up front. This shot ![]()
Sorry I don't know why I thought that was a 23 ft boat. It just looks that big in the picture.
Think I will still try 3 on the plus side.
Display Modes | |
