Old 08-09-2011, 06:16 PM
basswacker basswacker is offline
Default best bottom paint
what is the best kind of bottom paint for about $100 a gal, just want it to look good and get a couple years. i trailer the boat. how man gallons does it take to paint a 23?
Mmfishinglures.com
1976 23' Scepter
Lift weights get dates
Old 08-09-2011, 10:14 PM
BigLew BigLew is offline
Default Re: best bottom paint
For a New England season?
When I worked at Boat US I would purchase a gallon of their ablative and it lasted the whole season with no problems. My boat is also a 23' and it would be moored or docked in the Merrimac River in Newburyport.
As an employee, I paid as little as $6.83/gal for clearance stock. I would purchase next season's paint at the end of the current season when they would be blowing it out the door. At those prices and with that strategy, I would put a coat on every year. I will pay for it when the time comes though. I suspect I will bite the bullet and have it soda blasted. There has been about a 10-15 yr build up.
BTW, there are really only two companies making it and I forget who they were right now. I'll check to see if I can find out. Interlux and Petit are brand names for a parent company or two. Boat US would contract one of them to private lable their "shop" brand. You'll have to check the product claims against both the private lable and the name brand to try and determine which formulation you're getting.
PS. The only real problem I had was at the water line where the river water would deposit the typical scum through the season. It really had to be cleaned when hauled in the fall, otherwise it was a real PITA in the spring.
Plan accordingly!
Old 08-10-2011, 10:25 AM
bigeasy1 bigeasy1 is offline
If ever there was a product category that needed thinning out,it's anti fouling paints.I help a buddy out in the marine supply business occasionally,and I am completely confused by the sheer amount of bottom paints.There's ablatives,hard ablatives,conventionals,and within each of those categories there are all kinds of other formulations.There's Irgarol,biolux,slimeguard,Aqua guard,etc etc.
I shiver just thinkig about them and how to make a decision as which one to use.Thank god I don't slip my boat permanantly and boat in the fresh water of the great lakes.
I'm no help in which paint is best,but AKZO NOBEL CHEMICALS, is one of the largest makers of Marine and industrial paints.
They own Interlux,-awlgrip,-Sikkens,-Glidden and a load of other coatings companies.You may find useful data on one of their sites.
here's a link
http://www.international-marine.com/...outUsHome.aspx
All this,just for a boat ride
Old 08-10-2011, 04:32 PM
fdheld34 fdheld34 is offline
Pettit Ultima SSA..works good on my trailered boats both past and present...
can get 1 gallon under 100 bucks...2 coats of course!
I bottom painted my 20 foot Shamrock..had existing bottom paint on it...took 2 coats and had more than a 1/4 gallon left...8' beam
Painted my Grady White 20 footer with it..2 coats and had plenty...again existing ablative in both cases...1 gallon might do the trick for you..depends on coverage of bottom paint you select
Obviously stay away from hard antifouling!!
-Fred
Old 08-10-2011, 09:34 PM
@fdheld34
where do you get it for under WM has it for $128?
Mmfishinglures.com
1976 23' Scepter
Old 08-10-2011, 09:44 PM
one word....Ablative Dont start layering on cheap hard epoxy bottom paint year after year if you can avoid it. You will pay later with the sander
1974 23SF
Old 08-10-2011, 11:09 PM
boatbandit.com....
printout the ad from boatbandit for Pettit SSA Ablative..and take into West Marine..thus less than $100.00. They will beat it..at least my local store does!!!
-Fred
Old 08-10-2011, 11:54 PM
thanks
Mmfishinglures.com
1976 23' Scepter
Old 08-15-2011, 08:44 AM
Matt..how did you make out with WM discount on Bottom Paint
-Fred
Old 08-15-2011, 07:06 PM
i have decided to wait till spring to buy the paint. i leave for Mass Maritime this saturday so i wont have time till the spring to work on the boat
Mmfishinglures.com
1976 23' Scepter
