Old 09-01-2011, 12:49 PM
jaybap jaybap is offline
Default deck replacement cost
Hey guys, i recently just bought a 73' CC and theres a couple small soft spots in the deck. From your experiences whats it going to run me to have a new deck put in by a professional?
Old 09-01-2011, 01:29 PM
Tashmoo2 Tashmoo2 is offline
Default Re: deck replacement cost
I got a quote of $10k for an 18ft '85. It really depends on how much work you want done and how you want finished product to look.
You probably have a wet transom too which should at least be checked with deck out.
Old 09-01-2011, 02:38 PM
the transom has been redone and rainsed 5". Sold as a rock. Deck had been done about 8 yrs prior. Get the impression it was done that well.
Old 09-01-2011, 02:58 PM
If you have a few small soft spots . . . why would you rip out the entire deck? unless you are planning on raising the floor 3" . . . just fix the soft spots. Way less work and way less material . . . the repair will be just as strong.
http://www.westsystem.com/ss/assets/...aintenance.pdf
Page 32, 33, 34 replacing damaged core
Old 09-01-2011, 06:09 PM
jaybap,
I met the people from Metan Marine last year at the Newport Boat show. They have repaired many Seacrafts and the work is excellent. Maybe they can take a ride over to inspect boat. At the very least bring some pictures to the show.
Old 09-04-2011, 11:06 PM
GodsReel GodsReel is offline
test the whole deck, only repair the bad sections, i have done two 23's , the first i skinned out a lot of good balsa, the second i had learned from the first and only repaired what needed it. I did the skin the top layer off method, and recore and replace skin.While your at it i would check the cap for core issues and do them as well.
Old 09-14-2011, 02:07 PM
TooFly TooFly is offline
This ain't my thread... but thanks Bigshrimpin!
1969 20' Potter SeaCraft
2007 150hp Evinrude E-TEC
