Old 06-12-2012, 11:22 PM
good news is steering is fixed. bad news is boat is still sad. we water tested again with mechanic today, swapped in a known good computer and have the same issue. by passed ecu controlled ground with same result. bypassed power with same result. eliminated a harness problem. good news is he is not giving up on the motor.
Old 06-13-2012, 07:51 AM
I'm on my 4th OX66 motor and hope it never dies. Is there still an anti-siphon valve at the tank? Is the tank vent clear?
Old 06-13-2012, 02:16 PM
fuel starvation and fuel delivery issues have been eliminated. same result on an external tank
Old 06-13-2012, 02:53 PM
hugo hugo is offline
so your losing spark? realy need to read manuel and know how the safty systems work to have a good understanding of why it is shutting down.
Old 06-13-2012, 03:28 PM
csurf csurf is offline
Give these guys a call and ask for Chip (he's the owner).. they are Yamaha magicians and are always willing to help if you're a customer of not. If it's something they never encountered before they will bend over backwards to figure out the problem.
http://www.accuratemarine.net/
1980 23' SeaCraft
1992 16' Steiger Craft - Custom Flats Boat
The sea finds out everything you did wrong.
Old 06-16-2012, 10:25 PM
it is fixed! great fathers day present. the oxygen density sensor was the cause of the 4k rpm shut down. took it out today for a test and ran great with no issue at all.
Old 06-17-2012, 12:13 PM
Excellent! Great day to be out using that motor!
