  #31
Old 06-10-2012, 12:51 PM
hugo hugo is offline
been sick last two weeks and havent done much, had enough energy today i went outside and made my template and cut my two core peices out. then ran out of steam. hope i get over this crap soon....
Old 06-10-2012, 04:12 PM
i feel you about running out of steam. it is HOT outside today.
Old 06-10-2012, 08:57 PM
CATmech945 CATmech945 is offline
Oh yea! It was a cooker today. I spent the day grinding stress cracks out of a 22 shamrock and cleaned out a case of water. Sorry to hear you've been under the weather hugo. A couple guys at our shop have been out too, so that stuff's makin it's way around. Wish I lived a little closer, I'd come give you a hand with that boat of yours.
Old 06-11-2012, 11:39 AM
well i have seen several diffrent ways people lay up their glass work, some make the core first then install and cover and some layup in layers until done, any ideas which is better? or realy just a matter of what is easier? i can do either just wondered if it made a diffrence. i even saw one person make the core, cover it and then glue it in place and tab in the edges.
Old 06-11-2012, 12:26 PM
Hugo I would love to come by and see your work
I'm in Miami near the Falls so I think I'm close
I know that someday I will also do the transom on mine and I would like to see all that's involved
Sent you a PM with my contact info
Jorge
Old 06-11-2012, 09:50 PM
well a bit more grinding today and test fitting the wood core peices. have my glass cut out and my resin is in the fridge cooling out, tommorow after work god willing i will assemble the core and get a step closer to being back in the water.
Old 06-12-2012, 07:48 PM
one more step... wet out the wood and added 2 peices of 1.5 oz mat then wet them out and sandwiched and screwed together...... just not enough time after work to feel like i got much done...... maybe i can get it cleaned up tommorow and set in place to cure so i can glass this weekend. should i use mat or roven between the core and outer skin or just thicked resin to set it in like a putty?
Old 06-18-2012, 08:14 PM
Default back at it again...
well finaly was able to get the core set and filled in the sides and bottom. today i was able to get my wifes help and we glassed in the front side of the transom. two layes of medium mat with one layer heavy roven in the middle extending forward about 6 inches, lots of patches first over the fillets. and as my girls put it a penny (heads up for luck!). hope it dosent cause some reaction and mess me up! feeling good about the progress. more glass on the back to do then build the rear cap and floor. install the bracket and hang power! sounds easy enough
Old 06-18-2012, 10:52 PM
Looking Good and the wife helped!!
You need to teach some of us that trick
Old 06-21-2012, 01:17 PM
yea shes a real trooper! but i just cant get her to grind fiberglass! Lol
