Old 06-26-2012, 10:19 PM
hp02043 hp02043 is offline
Default Scuppers under the water line?
Just test drove an 89 20" SeaCraft (tracker?)
Water came in the scuppers when we were at the
Dock. Drained when the boat was pulled on trailer but
What if we are planning on mooring? Will it drain and
What about rainwater draining? Also 2 soft spots
Next to where the seat was. Nothing is there now they
Are mounting a leaning post for us. Thoughts?
Old 06-26-2012, 10:24 PM
jerry1 jerry1 is offline
Run
Old 06-26-2012, 10:58 PM
Do the scuppers drain straight down through the hull or out the transom? What size and weight motor is mounted? Heavy motors often cause the scuppers to ship water at rest, especially if someone is standing in the boat. Remember that the 20' SeaCraft was designed to have a motor of UNDER 300 lbs max weight.
Do the bilge pumps come on? Resealing the scuppers is a relatively easy task. Soft spots in the deck are manageable as well, if the price is right.
Fr. Frank says:
Currently without a SeaCraft
Old 06-26-2012, 11:03 PM
It has a 150hp Johnson and there is a steel plate
On the transom. Not sure why? Scuppers drain out the
Transom and both are underwater line at dock with no one onboard
I did not hear
The bildge pumps come on? $7500 there are a bunch
Of pics on my other thread under my name 89 20" SeaCraft so you
Can see it and the transom plate.
Old 06-26-2012, 11:30 PM
Mind add just sbove thebwater just. With a johnson 150 of course if im in the back water will come in but not with nobody in the boat.
82 seacraft 20SF
Bayview Canvas
Old 06-26-2012, 11:36 PM
An '89 would be a Tracker model that I'm not too familiar with. Do the scuppers run out thru the transom or are they the Potter style vertical type that go straight down through the hull? The Rabud ping pong ball check valves work pretty well on the transom-style drains.
That's a pretty common problem with the vertical scuppers if the motor is too heavy. Most folks don't realize how efficient the VDH hull is compared to the average deep-V, so they install motors much bigger than necessary. Carl Moesly designed the 19/20' hulls in the mid-60's when the biggest outboards (100-150 hp I-6 Merc's and V-4 OMC's) weighed about 260-300 lbs, and they're easily self bailing with those motors.
If you hang a late model V-6 2-stroke of 400+ lbs. on 'em however, you can expect to get wet feet. The 4-strokes are even worse at 450-500 lbs for the 150 hp and larger motors. It gets even worse if you install a bracket without a big flotation tank and move the motor back 30"! Moving the console, batteries and gas tank forward helps. The early Black Max V-6 Mercs aren't too bad at less than 350 lbs and the 60 degree OMC V-6's are about 375 lbs. Most folks just run with the plugs in most of the time. My Seafari is less stern heavy than the CC models, so my deck is about 1/2 to 1" above at the dock with no one aboard and it drains washdown and rainwater, etc., but I wouldn't be comfortable leaving it on a mooring. My 150 E-Tec weighs about 430 lbs and is on a 30" setback Hermco bracket, which has the most flotation of any commercially available bracket. CSC forum member Fellowship invented a clever check valve using PVC fittings, O-rings and rubber glove fingers that fits into the vertical scuppers that works reasonably well. Use the search function to look for a thread on the "Vortex scupper plugs". I use them when diving to keep excess water off the deck when it's already wet anyway.
PS. Just saw your last post. That steel plate on the transom is a red flag . . . it might be a band-aid for a soft transom!
Old 06-27-2012, 06:21 AM
Thank you. The scuppers are in the transom (they are
In the lower back corners of the boat). I think I may need to
Hire a surveyor if we are serious about this boat?
Old 06-27-2012, 09:02 AM
bilgerat bilgerat is offline
get a surveyor to look at it, if has soft spots in the floor and a bad transom its not worth anything near what they are asking.
Old 06-27-2012, 11:17 AM
The weight of a waterlogged transom or floor in the back could easily pull the the waterline down where there could be a problem like you described. Imho, don't fall in love with it if you have to reach on price. Like many have said the metal plates are put on as a crutch 99.99% of the time.
Old 06-27-2012, 02:57 PM
cbboatworks cbboatworks is offline
run like you stole something
