Old 07-18-2012, 03:48 PM
bassable516 bassable516 is offline
Default bassable516
What is the problem with the 23 seacrafts from 1980 to 1990. I am new to seacraft community. I previously owned an infamous 31 bertram. I need some help looking to purchase one?
Old 07-18-2012, 08:12 PM
No problems unique to that era. There's wood in the transom, the deck and the cap. It could be fine, it could be mush. Except for the keel stringer, which is a glass encapsulated 2x4, the stringers have no wood. They are foam filled fiberglass boxes. If it's in good shape, it's just as good as any other era Seacraft.
Welcometo CSC,
Dave
Blue Heron Boat Works
Old 07-18-2012, 09:45 PM
Just a bit of information
My '78 had a glassed in 1/2 of a 4" PVC. The wood keel stringer was used in the earlier years to beef up the keel due too center roller trailers which were commonly in use before 'Float on' type bunk trailers. I don't know what contruction methods were used in the later 80's ?
Below pictures show the PVC Center stringer before & after I removed half of it.
Old 07-25-2012, 09:26 PM
bassable bassable is offline
Default seacraft 23
This boat was always trailered and stayed in shed storage on bunk trailer.The general condition is average I will inpect all areas you mentioned. Thanks.
Old 07-26-2012, 12:10 PM
castalot castalot is offline
Also check the wiring or just replace also check switch panel half of mine didn't work
Old 07-26-2012, 12:23 PM
countshock countshock is offline
My '79 also has the half round pvc instead of wood.
