Molding clay
Can anyone tell me if you have usesd clay from local hobby shops .. Was wondering if i can get something that will work locally for molds.. Or do u recomend the mold clay fiberglass co sell..materials will be here tues so i will be building decks soon.. Thanks martin
Hobby shop clay works as long as you don't get the kind that hardens when you bake it. It can be hard to find the old style oil based clay, but it works just fine. Make sure to get good coverage over the clay with your PVA or the oil in the clay will cause your gelcoat to alligator.
Dave
Thanks guys...
temp rating for what?
strick |
Clay
Of the clay.. Or am i digging to deep for info . Trying to find an equivelant .. I have some @150f... Wondering if it is the same
I'm not that much into it. I'll take a look at the box to see if there is a temp rating. I just put it on the mold and glass over it
strick |
If it has a temperature rating on it, it's probably of the polymer thermoset type I was talking about. You want the oil based stuff that doesn't set when you bake it. The thermoset stuff will work, but the oil based clays are a lot easier to work with.
Dave
I have been told that you should use a low sulphur clay when making silicone molds. Do not know if there is any reason to apply this advice to epoxy or glass. Sulphur in the clay can effect curing of silicone.
