  #281
Old 10-02-2012, 12:58 PM
Jeswick Jeswick is offline
Hi there,
Been following this thread for awhile.
Really admire your work.
Anxiously awaiting updates.
Cheers,
Old 10-05-2012, 09:36 AM
Thanks, top and glass coming soon...will post when they are installed.
Old 10-20-2012, 01:04 PM
Default Rub Rails
Originally the transom did not have a rub rail on it. When Strick was on vacation in FL. we had a chance to boat BS and he thought a rub rail all the way around would look cool. WHO am I to argue with the guru himself
A friend came over to lend a hand. The transom was a learning curve since there was no easy radius. Almost 90' bend. Had to die grind the back and use a heat gun, but it worked.
Transom,
Side view,
Side with scrap of stainless,
The rest of the rub rail should be easy. However I know when I get the S/S inserts that transom bend will be tricky.
Old 10-20-2012, 03:53 PM
When there's a will there's a way Like the color choice on the bimini also. That is an incredible boat. Thanks again for having us....well be back!
Old 10-21-2012, 11:04 AM
Lookin` good. Does the rub rail go on prior to paint?
Old 10-21-2012, 01:22 PM
Good question!
Short answer no...I wanted to get the transom part done and drill the holes before paint. In case there was any F/UP'S and there was.
So now I will take the rail off fair in a few wrong holes and be ready for paint.
Old 11-11-2012, 09:30 AM
Default Last Piece...
Well I finally got the last piece of the windshield puzzle solved.
Awhile back I posted this picture and asked for some ideas on supports.
The best one was to copy Blue Herons idea. Dave was kind enough to make me two supports. Unfortunately when I got them they did not fit because after I routed the rabbet for the glass the support was a little to wide . Back to the drawing board.
The support had to full fill 2 criteria. 1. support the windshield and 2. provide a strong hand hold.
So here is what I came up with...3/4 inch S/S rod compound miter cut then drilled and tapped. Again it is nice to have a friend in the machine shop business.
The rod drilled and tapped.
Close up of angle cut
Nice tight fit
Front View
Both
Extra Hand Grip and Glass
I think this is the final hole drilling and fitting before going to paint...
Old 11-11-2012, 09:35 AM
castalot castalot is offline
Wow nice
Old 11-11-2012, 09:43 AM
BigLew BigLew is offline
VERY nice work there!!! Kudos
Plan accordingly!
Old 11-11-2012, 07:18 PM
paulmv17 paulmv17 is offline
Please please take alot of pictures when you get to the point of installing the glass. I'm going to building a new windshield soon. I'm not really sure how I'm going to keep the glass in.
