  #201
Old 01-31-2013, 10:17 PM
Lookin' GOOD!! No rat's nest there...
Old 02-13-2013, 08:49 PM
zendora zendora is offline
Wow, great work. Doghouse looks awesome and wiring is immaculate.
1978 23' Savage I/B
ZEN http://s1080.beta.photobucket.com/user/mfeenan/library/
Old 03-04-2013, 06:22 PM
I'm now working on the rigging lots to do. Question though wondering what people use for transducers on the inboards transom or thru hull looking for a 1kw also were would you put it
1979 Septer I/O no power Sold
Old 03-04-2013, 06:39 PM
Default Transducer
Im using the cheap transom mount with my furuno 582 and it really works great
Old 03-04-2013, 06:42 PM
I have an Airmar B164 mounted just port of the keel stringer, just a little forward/under the tranny. Basically the same spot as the raw water intake, just on the opposide side of the keel.
1978 23' Savage I/B
Old 03-04-2013, 09:41 PM
Keep up the good work, everything is looking great.
Will
Old 04-06-2013, 08:48 PM
So update: I have received the 17x19 dqx prop. Engine is aligned and working on the raw water just tricky because of the size of the engine tight space to work in. Also figured out the exhaust I'm ordering a snail elbow for a out drive should raise it up about 6"
Old 04-29-2013, 09:56 AM
Highway12 Highway12 is offline
What is a snail elbow?
Old 04-29-2013, 02:30 PM
GoodChance GoodChance is offline
An exhaust riser off the turbo of the engine.
The key problem with inboard engines is the tendency for saltwaterto enter the engine/turbo coming INTO the exhaust. While the engine is off, it is very common in poorly designed exhaust systems for a "slug" of saltwater to come up the exhaust tube and into the engine. To prevent this, you need 2 things: 1) a surge tube and 2) a riser that has it's lowest point at least 12" above the waterline.
The Idiot Who Re-Built the Burnt-Up 35 Duffy
Old 04-29-2013, 08:28 PM
Snail elbow looks like its name and it gets me the Clarence I need above the water line
