Old 04-15-2013, 10:20 PM
GodsReel GodsReel is offline
Default Change thru hull on front fish box on 23'
What would you guys suggest I use to change thru hull? I did get a flange tool this time.
Old 04-17-2013, 10:04 PM
Billpotter Billpotter is offline
If you remove the old drain sleeve, and the material between the hull and the fish box liner is solid when you poke around with a screw driver, you can use a brass sleeve bathed in 5200, and your flaring tool. If the area between the panels is in poor (mushy/ loose) condition, I'd use a suitably sized bronze thru hull (same hole size or larger) bathed in 5200. That should, with regular monitoring for leaks, provide a solid reliable seal. It worked on my 18 for 12 years.
Good Luck!
Bill Potter
18' 1978, Yamaha 130
23' CC 1986, T Suzuki F115s (current full custom project)
Old 04-18-2013, 07:02 AM
Thanks Bill, that's what I thought , last time I did it was solid I have never had proper flange tool therefore never got good seal .
