  #371
Old 05-25-2013, 09:05 PM
jdandme jdandme is offline
Red face
Need more pictures!!! I'm addicted!!!!!!!!!!!!!!
Old 05-26-2013, 05:48 PM
castalot castalot is offline
Your not the only one
Old 05-26-2013, 07:38 PM
Terry, you have made many considered choices. Congratulations. I hope to do so well.
Good luck with that... right. We had a fun day on the Right Hook. Mike is fun to fish with. I think I missed more hits in any one day of my life today. I will now crawl under the carpet.
Humble GFS. Really upset...still.
Old 05-28-2013, 07:46 AM
Well after terminating and butt splicing and laying on my back for a couple of hours I got bored...
Laid the first part of my "Boot" stripe to see how it will look.
Basically the painter (ease of layout) cut the blue and white at the hard chine. I just brought up the white 1/4" to give the color a pronounced separation. The next stripe will be up by the water line. Still deciding how wide.
BEFORE,
AFTER, very Subtle
Need to get some more terminals and wire so the wiring end can be completed...
Old 06-22-2013, 09:35 AM
Default Always Something
Not much progress for the last three weeks (on a road trip). So now it is time to button this up.
In my post #357 when I was installing the head, I needed to install a shut off valve on the thru hull fittings for the head. One was real easy and the other was a real PIA.
The problem was that in order to close the valve I had to reach under the floor. This is where the challenge began. It was hard to get my hand around the lever to force the valve close and to get leverage. There was not enough room as the pictures will show.
So the solution was to make a paddle out of the lever and now everything works very smooth.
Valve without Lever under the head.
Orignal Lever
Solution Paddle Lever
Open Position
Closed
I think Strick once said if it was easy everyone would have a Seacraft
Old 06-24-2013, 02:05 AM
Good old southern engineering...... from a northerner and one more hurtle passed. Looking good Terry!
Old 07-01-2013, 05:45 PM
Why don't you just get the guy/girl that's in there with the camera to close and open it when needed?
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 07-04-2013, 11:40 AM
Default Dash Wiring
Well after spending countless hours on my back in weird positions. Terminating at least 40 wires then heat shrinking them, labeling now I can finally say that the dash is 95% wired (you can never say 100% cause you will add something sometime )
Stuff all over the place.
Behind Dash
Switches wire and labeled.
I let the natural torque of the wire load level the body of the switch to where it wanted to sit. Since you can't normally see it, who cares if they are not equal.
Fuse box with and without cover.
Dash and Switch Panel
Now to drill another hole in the bottom and install my transducer and run one more wire to the front...
Everybody out there enjoy the holiday...Happy 4TH!
Old 07-04-2013, 04:22 PM
WildBill WildBill is offline
Nice work. It looks nice and clean.
bill
Old 07-04-2013, 09:46 PM
Yer makin' progress, Terry. You'll probably be done in another year or two.
Dave
Blue Heron Boat Works
