Old 10-05-2013, 06:40 PM
abl1111 abl1111 is offline
Default Removing snapped drill bit ?
If anyone has a solution to removing a snapped drill bit from a cylinder head ( done while trying to tap out an already snapped bolt ) = I'm all ears.
Happened on a 4hp outboard - an OLDIE but a goodie..
Is there a drill bit that will drill through the snapped drill bit so I can then re-tap the hole ??
Old 10-05-2013, 07:18 PM
you might have to go at it with a dremel. then get a timesert kit and your good to go.
Old 10-05-2013, 08:18 PM
Depends on hardness and size of the bit that broke. I've used a smaller cobalt bit to start hole on the broken bit or bolt, and then used a screw remover bit and wrench to remove bolts and bits alike - but its a pain. imagine a cylinder head hole is probably 3/8" or so, so that's an advantage over something smaller. dremel with a diamond tip would probably start the extraction hole better than a even a cobalt drill bit. Good luck, sounds like a PITA..oops 4hp bolt might be a bit smaller...
Old 10-05-2013, 08:58 PM
Thanks guys - I like the dremel / diamond bit. I'll try it ! Totally PITA. 1972 !!!! 4hp evinrude - runs like a top for the 1 hour used seasonally when the wind totally dies on my day sailor.
It was running HOT when I went to winterize it - I had just replaced the impeller last year so I figured I'd check the cylinder / exhaust plate for blockage and gasket issues. Snapped bolt on inspection. All was OK in there anyway !
Dropped the lower unit. Turned out that the copper tube feeding the powerhead and fed by the impeller housing was clogged ! Straightened a hanger, unclogged it - but now this snapped bolt is allowing exhaust plate to leak !
Aaah tinkering. But, I figure even a pro would have had that same thing happen too. Wife thinks I'm insane. I try to explain, some guys watch sports or do crossword puzzles - I fix things ! You should see my fully restored 8 hp 26" snowblower ! I'm sick - I know !
Old 10-06-2013, 12:48 AM
I've be told an important reason for changing your impeller every year or so is to keep the lower unit bolts from corroding and snapping. Go figure. good luck tinkering
Old 10-06-2013, 04:48 PM
Used the diamond dremel - it did not cut but a benefit is that it loosened the bit and I was able to fish it out while twisting with two straightened dental picks.
Then I cleaned the hole with a tungsten bit. All tapped and done...
Thanks guys !
Old 10-06-2013, 09:05 PM
Glad to hear you got it taken care of without too much trouble.
Old 10-07-2013, 09:17 PM
You know those breaks can be hell. Lucky it was a bolt that snapped in a spot that the powerhead didn't have to come off to access it ( like 3 of the 8 are ) and that it was loose enough to get out that bit out. Otherwise I would have been in trouble.
Thx again.
Old 10-09-2013, 03:29 PM
OilFieldMan OilFieldMan is offline
When I break bits, I use a punch and hammer it into pieces to remove it. Less risk of damage to threads.
1974 Seacraft 20' SF with 1985 Evinrude 150 VRO
1987 Seacraft 23' Scepter with 2007 250 HP Evinrude Etec
Old 10-10-2013, 09:58 AM
Originally Posted by abl1111 View Post
. . .Are there any other techniques to remove a frozen bolt that could help avoid the dreaded 'SNAP !' in the first place ? Besides obvious preventative stuff like using anti seize etc...
I spent about 35 years developing new jet engines that run so hot that conventional anti seize products don't work; in fact they would oxidize and actually make the problem worse! Other than heat and/or liquid nitrogen, and Zyglo fluid (used for florescent penetrant inspection), this is some of the best stuff we found: http://www.kanolabs.com/google/ Good hardware stores sometimes carry it but you can also order it from Eastwood http://www.eastwood.com/kroil-penetrating-oil.html
