  #121
Old 01-01-2014, 01:14 AM
Looks nice, simple and effective. What are your plans for your helm pod? Something Carolina custom-ish?
Old 01-01-2014, 08:44 AM
martin martin is offline
Yes .. Carolina style . With a electronic pop up
Old 03-11-2014, 01:19 AM
okay back at it .. peeled all the core material off the center deck boards and ground down. going to replace with foam core.... added a few more pieces of foam core around the gunnel cap for the rub rail. and prepped and coated the twin bracket..last coat for bracket went on tonight..
Old 03-11-2014, 01:25 AM
Default center deck
here is how I removed the core material, I just cut around the edge with my 4' dimond blade. and then peeled the skin off
Old 03-11-2014, 01:26 AM
after clean up I wet out a layer of 1.5 oz matt
Old 03-11-2014, 01:29 AM
Default wet out glass
1.5 oz matt to give the foam a nice bed to bond to
Old 03-11-2014, 01:32 AM
I gave them a quick sand down today. and had the bright idea to try the RESIN INFUSION TECNEQUE Well it sounded good. Trying to elimated a couple steps... I did not have the proper equipment . other than a vacuum pump.. so here it is
Old 03-11-2014, 01:33 AM
Default Rtm
Cool at first, then well, it got messy
Old 03-11-2014, 01:42 AM
Default here you go
sucking it in
Old 03-11-2014, 01:46 AM
Default fishing product
not bad for the first goat rope-in. With out the proper equipment
