  #131
Old 03-11-2014, 01:50 AM
martin martin is offline
Now on to the bracket for the boat. First I used my water sandblaster that I got from northern freight. did a quick blast. ten I used ppg alum. prep.rinsed real good. and then used ppg barrier coat. dry out is the sun . then applied three coats of belzona5811 and made sure I hit all the nook and crannies.
Old 03-11-2014, 01:54 AM
Default bracket
prep work
Old 03-11-2014, 01:56 AM
Thats about it for now. Tues I will be finishing ou the deck boards and building the gas tank beds. Going to try to blast the bilge.
Old 04-05-2014, 04:59 PM
Finally got the fuel tank bed glued down. Between the glassing and kids fighting and one going in the water.. I was not able to take as many pics as I wanted...so here is the tank bed being layed up..
Old 04-05-2014, 05:12 PM
Default tank bed
I will tab it is after the cabosil compound kicked off.. Then gel coat
Old 04-05-2014, 06:11 PM
Great work, great documentation. I am a month or so away from starting somewhat similar mods on my 25, so the pics are appreciated.
Old 04-05-2014, 10:44 PM
Thanks for the compliment...there are so many other things i wish i could have documented . I mean alot more pictures would have been good...
I dry fitted the 9' bed a few times to get the height ringt.. I then knew i had to install a center stringer to help spread the load .. That was a major pia.. Especially by myself..i lamenated two3/4" foam boards to gether and then.. Be gan sanding the piece slowly down to get the correct spacing between the bed and center keel..i covered it in a layer of1808 and down each side of the stringers port and starb to give the bed some fresh glass to stick to..while tacky. I piled on the resin cabosil putty on the keel and down both sides then i carefully set the bed down and wedged whatever i could find to keep it down.. Cause the bed had a slight crown.. Which to me is good...
Old 04-06-2014, 12:44 AM
fishinonthebrain fishinonthebrain is offline
Looking good Martin. Was that bubble wrap you used in the vacuum process?
Did you use regular epoxy for the layup?
Old 04-06-2014, 07:26 AM
Yes just plain bubble wrap.. I prefer the large bubble wrap but this is all hd had at the time..
Polyester resin is all I'm using for now..thanks fish on the brain
Old 04-07-2014, 12:29 AM
I'm impressed. I'd like to try and vacuum bag something soon. maybe I can give you a call when I'm ready?
