  #41
Old 06-03-2014, 10:04 PM
seabass08 seabass08 is offline
Thumbs up Photo update
Sea trialed the boat this week. The difference is huge. The boat sits much higher in the water now and the water line is 3-4" lower than it was. He did a ton of work to the boat including replacing the transom, building the new bracket that extended the running surface of the hull, moved the scuppers to the transom,re-rigged the engine, pumps, trim tabs, moved the plug to the bottom of the hull, re-sprayed the transom and rear portion of the hull sides in Awlcraft 2000 to match the existing paint, moved both the leaning post and center console forward about 12", etc... The boat now sits much more level in the water now. It planes at a much lower speed but I didn't have the electronics hooked up so we didn't get speed and mpg data yet. The motor needs to be raised up one hole so I will update when I have more data if anyone is interested. The improvement in how the boat runs and handles is much more than I was expecting. The old waterline/scumline was in the middle of the blue boot stripe. pics to follow...
Old 06-03-2014, 10:22 PM
included a few of the bracket build/design as well
Old 06-03-2014, 11:42 PM
Brilliant! Now, for a Guinness!
Old 06-04-2014, 06:55 AM
kitebuz kitebuz is offline
That came out great! Congrats on both the looks & improved handling/balance. I will he very interested to see your #'s & how they compare to a stepped up bracket.
Did he make a mold for the bracket & bolt it on, or do a hull extension mold & glass it in place? Also curious if he tied it into the existing stringers. You've got me seriously thinking about how to do my new bracket vs hull extension.
Old 06-04-2014, 08:43 AM
A welding buddy of mine wanted to do a bracket like that for my old boat out of aluminum, except that it would have been wider according to his explanation. My modification would have been to allow enough of a flat spot at the bottom so the existing hull drain plug could be used. There should be more drag with the extension but adding the flat spot at the bottom I thought would help it act more like level (huge) trim tabs with less drag.
Old 06-04-2014, 09:28 AM
Thanks. When he replaced the transom he tied the stringers into the transom, added knees, and glassed the deck to the transom as well. Then bolted the mold to the transom and layed up the mold glassing it to the transom then through bolted the bracket to the transom. Its more elaborate than that but that was the basics of it. Billy could answer more detailed questions about it. Both the new transom and bracket are seriously stout.
Old 06-04-2014, 09:38 AM
Talking
This was the first time I have even been able to run the boat without using the trim tabs. Didn't matter if I was going 3mph or 45mph I have always needed them to get the boat to ride even remotely flat. It now sits, accelerates, and rides very flat and even, slow or at speed. I'm sure there is more drag but I have a slower plane speed now which will result in better economy and a better ride in rough water and no bow wave to push over to get on plane. There are trade offs no matter what path you take I think. So far I'm very happy with the result.
Old 06-04-2014, 11:33 AM
Very nice indeed! Looks like a lot of added floatation volume. I'm curious how it dose turning with the extension? Glad it worked well for you
Old 06-04-2014, 12:24 PM
Boatboy6 Boatboy6 is offline
Wow she looks great! Hope to see you around this summer.
Old 06-04-2014, 09:16 PM
My expectation was that there would be some issues with higher speed sharp turns but surprisingly that was not an issue at all. I did not notice any difference.
