Old 07-14-2014, 07:33 PM
berts80 berts80 is offline
Default Cutting 1808 cloth
I'm trying to precut 1808 for my sole. The problem is stretching and fraying. I lay it down on a piece of smooth plywood and put a straight edge on top and run an box cutter knife down the straight edge. After the cloth is cut, I roll it up and unroll on a large flat area. If I try to move it around or handle it in any way it bunches up, distorts, and the edges start to fray. I have not had this problem nearly as bad with 1708. Do I have some bad cloth or is this the way it normally acts. Seems like it's going to be hard to lay one sheet beside the other and keep straight edges.
Old 07-14-2014, 07:51 PM
I use tin snips or "aviation shears" to cut mine. Works great on most of these fabrics. A knife will probably just make a mess like you are experiencing.
Old 07-14-2014, 08:28 PM
FLexpat FLexpat is offline
If you are not cutting a ton of glass you can get some pretty good scissors at BedBath&Beyond that have microserrations or teeth on one edge - I think about $20 - the teeth hold the glass while you cut without fraying as much. They start getting dull after trimming about 20-30 yds so if you are doing more than that practice sharpening or get real glass scissors - I think Joel Shine sells some at his shop (Bateau). A lot of others do too.
Old 07-14-2014, 08:57 PM
CoreyTrx CoreyTrx is offline
Don't roll it up after you cut it. Leave it flat or fold it if you have to but don't make hard creases.
Old 07-15-2014, 12:35 PM
When I said box cutter knife I should mention the box cutter uses razor blades .
Old 07-24-2014, 09:30 AM
curapa curapa is offline
I've used about 30 yards of the eBay 1808. I cut it with Fiskars shears with a serrated edge on one blade, cuts easy with no fraying.
Old 07-31-2014, 09:35 PM
martin martin is offline
1808 0-90 or 0-45 stich
I've used friskers rotary cutter with pretty good results..
Old 08-01-2014, 02:47 PM
oldfielder oldfielder is offline
Shears always worked great for me.
