  #161
Old 10-08-2014, 05:04 PM
martin martin is offline
Default gel coat pic
Gel coat
Old 10-08-2014, 05:05 PM
Sorry it was in reverse..
Old 10-08-2014, 05:10 PM
Default toe kick dry fitted to console..
Popped the toe kick out.. had some crazing but all in all it will do.. Lots of grinding and fitting. I did not have a chance in between to take pics..
Old 10-11-2014, 11:29 PM
FAS FAS is offline
awesome job on the whole project...you will have an excellent resto..keep photos coming....
Old 10-13-2014, 09:44 PM
Default Console
Thanks Fas,, definitely a learning curve ...and just when you think all is good. I have a bad laminate on the bottom of console.. Apparently my bonding of the foam to the pan bottom. Did not take. So I measured 1" from perimeter and cut the bottom skin. Then pulled the skin off the foam. The foam is to saturated with non-cured resin that it needs to be replaced. So that is we're I am at... I guess I did not compensate for the drop in temp, When the last front came through .. Now I need to fix it...and we'll my 23 fell from the cradle in the boat house.. Yea I know right., the cables broke and down the bow went .. Then 5 seconds later which seemed longer the stern drops..thank God my kids were not near... I was just under the boat yesterday check out the bottom of bracket...No more cables.. I am now using dyneema braid.. Got the boat back up after spending all day raising her...please use lots of caution...
Old 10-14-2014, 10:44 AM
Default resin issue
Had to cut off bottom skin and recore..
Old 10-15-2014, 07:41 PM
Default removing core
Nothing fancy just really hard work especially when it is a redo over...
Old 10-16-2014, 06:37 PM
WildBill WildBill is offline
My Dad use to say; "If you can't do it twice, it's just not worth doing"
Old 10-16-2014, 09:00 PM
I hear ya... That goes for the boat lift to ... I will be redoing that one soon....well I got all the core out . thank god I over lapped the glass. In other words, I isolated the bottom and side core from the top core... So all I need to do is wash with acetone or denatured alcohol and let it bake in the sun... Then recore... This time I am going to encapsulate the vertical core. Then the bottom core... Trying to save a step before cost me a lot of disgraceful agony...
Old 10-19-2014, 08:59 PM
Default back on track
Sorry for not posting more pics.. I have been away for a qhile ..but I got after it today and finished recoring the sides and bottom of console.. Now to prime it and finish filling voids and more primer..
