Old 10-04-2014, 04:42 AM
I would suggest raising the deck and rebuilding/replicating the channels
Old 10-12-2014, 10:28 PM
FAS FAS is offline
doing the same thing right now on a 85 23 SF.its stripped down all way and new floors going in.i will keep the channels and scuppers.would like to do it without wood floors but not sure how to keep it straight with foam. Now, it is at ,no floors , only stringers. It had shims and green putty keepin it level .the hard part is the lip for the hatches to be correst.any help is appreciated.how do I send picts???lots to come.....
Old 10-13-2014, 12:45 AM
FLexpat FLexpat is offline
FWIW I'm gonna do my 23 Sceptre I/O decks and try to keep the gutters. Here is the short version of my plan if it helps:
  • cut the deck out 2" inside the edges, leaving the bottoms of the gutters as tabs on the liner,
  • Pull the deck top skin
  • Recore the deck outside the boat with Corecell and extend the edges out 2" with glass (finish the surfaces as much as possible while out too)
  • Bond the deck back in on top of the stringers and tabs
  • Fair in the edges
FAS - for how to do hatch lips on new decks look at Billy's thread: http://www.classicseacraft.com/commu...ad.php?t=24262
Old 10-13-2014, 07:36 AM
martin martin is offline
I just recorded my decks with corcell.check out my build on my 76. 23.. I am not to concerned with the appearance as I will be laying teak in my cockpit sole...build a lay up table and you can make top skins thqtvare nice and smooth and then cut and shape to the floor and bed the whole panel
Old 10-13-2014, 09:15 AM
cadeco cadeco is offline
Smile
I don't know how to do pics, but would love to see yours. ( We are in the same boat).
Old 10-13-2014, 09:16 AM
[QUOTE=martin;231451]I just recorded my decks with corcell.check out my build on my 76. 23.. I am not to concerned with the appearance as I will be laying teak in my cockpit sole...build a lay up table and you can make top skins thqtvare nice and smooth and then cut and shape to the floor and bed the whole panel[/QUOTE
I'am a newbie: How do i get to your tread?
Old 10-13-2014, 09:18 AM
Smile
  • Fair in the edges
I will for sure look at the tread.
Thanks
Old 10-13-2014, 09:32 PM
Default Thread
[QUOTE=cadeco;231455]
Just go yo repairs/ mod board.. And look up 76 23 restore, by Martin
Old 10-31-2014, 10:35 AM
Thumbs up
In redoing my 23 ' I kept the gutters however it was a lot of work . You need at least 2" min. To tie in the sides and I had cut about 3/4 of a inch from the edge closest to the center console.i hade to grind the channel and up the sides about 2" to feel comfortable then put 2 layers of Matt if I remember 3 of biax then 3 more of 11/2oz mat followed by a bunch of sanding the deck with a 9" side grinder working down to a DA and more hand sanding! If I where to do the decks again I would make a template then build the new deck on Melamane board and then just have to tie in the edges and save a bunch of time and money on the damn 9" discs alone. Resettle one of the guys sorry can't recall who did a beautiful job this way you could even do the gelcoat except for the edges where you would ruff them up and tie in
Do you have any photos of the work? ( Sorry for respond this late but i had an accident and won't be able to use the right hand for at least 30 more days)
