  #201
Old 11-12-2014, 09:46 AM
Bryan A. Bryan A. is offline
ha alright atleast someone is looking at it!!!
I know how you feel, I'm watching too, and taking notes.
Just finishing up fairing the transom on mine and ready for primer so I can move onto cutting the deck out.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 11-12-2014, 10:04 AM
bobbert bobbert is offline
Great work!!! Keep the posts coming! Always learning something new here.
Old 11-12-2014, 10:36 AM
And another one watching too, doing a great job too. Im contemplating putting a big screen navnet in mine but we will see what the admiral has to say about that
Old 11-12-2014, 06:51 PM
Boatboy6 Boatboy6 is offline
Speechless
Old 11-12-2014, 08:39 PM
FAS FAS is offline
I'm on it too....respect your work, great picts also....everybody's watchin !
Old 11-12-2014, 09:56 PM
ok ok good. just wanted to make sure it was worth posting still!!!
I did a little filling and grinding this afternoon, I cleaned the garage with my workers for the last hour of the day as it was a mess. It amazes me how much garbage you produce restoring a boat.
anyway I used the pastry bags and took a pc of it to show how they work. by now you know, I get messy with putty and fillers. I am like a little kid!
these bags make it much more controllable on how much to apply.
36' Yellowfin
1972 20' seacraft 140 suzuki
Old 11-12-2014, 10:01 PM
it was also time to put the console back in the boat for some measurements and to get feeling if I was missing anything. I am happy with the way it looks , livewell height along with the console and leaning post fit the profile of the boat.
next up is a little more tabbing, scuppers, and cut some holes for stuff. I am also gonna build a panel in the console to cover the livewell.
36' Yellowfin
Old 11-13-2014, 05:47 AM
At 18,000+ views people are watchin'! Keep up the good work and keep the pics coming
Old 11-16-2014, 10:59 PM
got some work done over the weekend
it was time to do the scuppers, decided to go out the side of the of the hull.
I used the long pilot bit, to scallop the floor for a drain. I used a 2.5 holesaw bit.
once I bottomed out I used the air saw to cut the piece out, I then proceededto core the balsa out from the inside. once that was out I cut and fit mat to the hole and wet out everything around it.
once that set I ground the goobers off and back filled the entire hole with dynaglass and smoothed it out. I let that set and drilled a 1 3/8" hole from the outside to center the dynaglass from the first pilot bit.
other than that I have just been tabbing and dry fitting everything I can.
36' Yellowfin
Old 11-21-2014, 11:32 PM
well it was time to put the boat on the trailer, so I made a call to a friend with a crane and it made very easy work getting the job done.
36' Yellowfin
