  #81
Old 11-30-2014, 11:58 AM
http://boatbuildercentral.com/prodde...=LM_9443_1%2F4
Use this to bed the to the tank. Also epoxy coating it will insure a longer life of the tank. Etching primer will be needed to bond correctly .
Boat looks good and clean work makes it easy
36' Yellowfin
1972 20' seacraft 140 suzuki
Old 12-01-2014, 11:13 AM
afishin82 afishin82 is offline
Thanks for the tips guys. I plan on etching then epoxy coating the tank. I wanted to use foam in a couple spots to kind of secure the tank a bit more than just the fasteners but scratch that idea I guess. Is the foam bad because it traps water against the tank?? I am also wondering how to ground the tank and boat? Should all the grounds (batteries ect.) and tank be connected?
Old 12-01-2014, 02:05 PM
Originally Posted by afishin82 View Post
. . . I wanted to use foam in a couple spots to kind of secure the tank a bit more than just the fasteners but scratch that idea I guess. Is the foam bad because it traps water against the tank?? I am also wondering how to ground the tank and boat? Should all the grounds (batteries ect.) and tank be connected?
Check out Dave Pascoe's article on how to install gas tanks if you haven't already read it - it's been posted on here many times.
Regarding grounds and bonding systems, check out the "Grounds & Grounding", "Bonding Systems" and "DC Systems" sections Pascoe's article on electrical systems. Some folks don't necessarily agree with every thing he writes, but I've read a couple of his books and many of the articles on his web site and he seems to have a lot of first hand experience with most of the stuff he writes about!
Old 12-02-2014, 12:55 AM
I would just ground the tank to the fill for safety against static spark when filling.
grounding system on a 20fter is a little excessive. I have seen stray current at a marina destroy a lot of stuff in boats that were bonded and grounded. that otherwise would have been fine
36' Yellowfin
Old 12-05-2014, 11:28 AM
If I were to cut out the transom for a 25" motor would the cutout be 25" above the keel? I am contemplating scratching the hermco bracket idea...
Old 12-05-2014, 11:49 AM
Bryan A. Bryan A. is offline
We did mine at 26.5" with advice from others on this site as well as the glass guy that helped put in my transom.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 12-06-2014, 10:02 AM
This^^^
Old 12-06-2014, 10:10 AM
Cool thanks for the info!
Old 12-06-2014, 10:24 AM
Definetly go at least 26.5 inches. Been there done that at 25 inch and I'm in the top holes still
Old 12-08-2014, 12:43 PM
So trying to decide which arjay product to use to bond the floor to the stringers. The core bond is polyester based and seems like it will do the job. The vinyl ester is a little more expensive and I'm just wondering if the extra money really needs to be spent.
