Old 12-11-2014, 09:37 AM
Originally Posted by abl1111 View Post
I will be doing some winter epoxy work and have limited experience with epoxy ( I've always used polyester resin ) and any epoxy I've used has been the West System - although never used with fiberglass - always used thickened, to repair a crack etc.
Is there a better, less expensive epoxy and where can I purchase it ? Or, should I stick with West ? I will probably not need more than a few quarts to a gallon.
Thx
The epoxy you might be looking for is called vinylester. Or more properly, epoxy vinylester . It works like poly and wets out mat. And has a nice low viscosity. And has mechanical properties better than West system epoxy.
Merton's sells it. Data sheet is attached.
Old 12-13-2014, 12:00 AM
martin martin is offline
I've used aero marine epoxy from cali good stuff and inexpensive. Used it for a teak sole and 3/4" covering boards held up very well especially when gluing oily teak...
Old 12-14-2014, 02:12 PM
bigeasy1 bigeasy1 is offline
Smile
Originally Posted by thehermit View Post
US Composites sells "epoxy mat".....NO Binder
Hermit,I almost forgot about that, thanks.
Yes,they do.I just don't care for it.It's thick and puffy like a blanket.I like a stitch-mat like 1708 as I find it to be much easier to use when dealing with bends and curves when wetting it out,it just drapes and conforms so nice,and is very user friendly.
It is also stronger.in structural applications.than mat.
To each his own though,everyone has their favorites,done properly,they all do a very good job.
All this,just for a boat ride
Old 12-14-2014, 07:34 PM
Me too
FYI
Vinyl ester is not epoxy. Poly type product right?!
1974 23SF
Old 12-15-2014, 03:54 PM
shine shine is offline
Moderator
We sell a lot of epoxies (mostly our house brand), and also biax with mat that is stitched. I rebuilt my seacraft with these materials. Our prices are very competitive.
our Marinepoxy....
http://boatbuildercentral.com/products.php?cat=41
Old 12-15-2014, 08:52 PM
abl1111 abl1111 is offline
Thx again. A quick question - do you think I need to use core material ( balsa ) and then 1708 or will the 1708 give enough rigidity under the gunnels ?
