Old 01-11-2015, 09:04 AM
I bet that layout cuts down on your top end....LOL
Old 01-11-2015, 03:46 PM
Superminoh Superminoh is offline
Oh yes island trader .but its great for backing down.heres a trial fit after trimming.
Old 09-21-2017, 04:10 PM
Its been a while, life got in the way,mom died ,6 brothers and sisters to settle will with and then had both knees replaced(should have done that a lot sooner). any way back on the seaCraft.got the transom in getting ready to tab it inside and bring stringers up to transom.All you guys posting while i was laid up had me chomping at the bit to get back at it.
Old 09-22-2017, 09:49 AM
Default transom
I would like to ask is there a reason why the stringers in 1971 20 ft sf taper down as they reach the transom.i have put two 3/4/ inch marine plywood in the transom and will be adding a bracket.Should i add knees to stringers and bring them higher on transom,are leave them as is?
Old 10-09-2017, 02:03 PM
Default more work done
Didnt get a response to knee question ,so went with my gut. got out the grinder Saturday morning and started going at inside of new transom skin to ruff it up. Same story ive read before .20 year old snap on grinder quit
working,so backup lowes grinder ,it quit .so off to tractor supply and got a new dewalt and that did the trick.Now have two layers of 1808 with 1708 sandwiched between.Put foam in place with a product called power grab for bathroom shower walls.3 layers of 1708 and 1808. after it sets real good (epoxy)i will grind all the ruff stuff down and add 2 layers of 8oz cloth with some white pigment to final coat .Next i will take out console and t top and start on floor and foam.BECAUSE OF HURRICANE HARVEY I WAS ABLE TO GET A 22 FOOT MAGIC TILT TRAILER FOR GOOD PRICE FROM SOMEONE WHO LOST THIER BOAT.
Old 10-11-2017, 09:23 AM
Anyone remember the guy who took out his fuel tank with a chainsaw
Old 10-11-2017, 01:23 PM
Ed Ed is offline
His name was Lt. Dan, right?
Old 10-11-2017, 01:55 PM
Default My tanks
MY TANKS ARE IN MY CONSOLE. What did the guy do ,forget to plastic coat the chain!!.In the old days we used to run a vacumn cleaner hose from the tail pipe of a running car into the gas tank,then weld are cut out, the carbon monoxcide are whatever its called would replace the oxogen so it couldnt blow.
