  #51
Old 01-14-2015, 10:20 AM
You bought your boat from George, right? Didn't it have twin I/Os? How far apart were they?
That being said, the original spacing may or may not have been ideal. I think your thought process on the pros and cons of wide versus narrow is good. As you said, the boat heels a lot in a turn, and that may cause the outer prop to blow out in a sharp turn. On the other hand, with outboards you have the flexibility to adjust engine height to compensate.
The best guy to ask would probably be bilgerat. He's got the only 25 I've seen with twins on a bracket. If he doesn't respond here, you should consider sending him a PM.
Dave
Thanks for the imput, True, I didn't think about the dimensions of the twin outdrives. They appear the be as close together as the motors would allow. I think there may be some clean water to be had in different spots off the vdh but after reading for hours I have a good idea what works best for most boats so I know where to start. There is also a fellow north of me in Virginia that has 76 25' with twin v6 mercurys on a bracket and I have spent some time talking to him over the phone. I would like to reach out to bilgerat if you read this give me a shout.
Old 01-14-2015, 01:54 PM
Default Twin Engine Set-up on VDH
I have a question for the knowledgeable up here, I have some questions about setting up twins on the 25' . . . Bushwacker, and any of you other engineers or experienced guys in performance twin set up help!
Friz,
If closely spaced motors see much air from that inner step on the VDH, they may be just as likely to blow out or might have to be trimmed down lower than if they were mounted further outboard! However I only know enough theory to be dangerous, and have absolutely no experience with twins and so I respectfully defer to bilgerat, and especially Fr. Frank, who has lots of experience rigging and running twins on very deep narrow hulls. Forum member Flying Time is a naval architect who also owns a race boat hull that's similar to your 25 and may also have some good advice.
I'd also suggest you send a PM to Carla (65Bowrider) to see if she can ask her dad what he'd recommend for a 25 Seafari with a bracket. I know he recommended the wide spacing for their Moesly 21 project boat which originally raced with the twin Homelites, both for "clean water" and minimum draft considerations. He also commented that the twin 250's on the bracketed 27' Seamaster "Sea Mistress" he bought were mounted too close together. Both of those boats have less transom deadrise than the 25 however, which may be a totally different animal. At the transom, GFS's race boat hull looks a lot like the 25 Seafari without the outer panels, so whatever worked best on the narrow race boat hulls might also apply to the 25. You probably have the motors mounted close together on your race boat, so that gives you a test vehicle that you could use to experiment with toe-in/out, etc. I'm sure that the Merc folks probably did lots of testing at Lake X on the race boats to determine what combinations gave the highest WOT speed. On a family cruising boat however, other factors like draft, handling characteristics, fuel efficiency, and low speed planing ability are more important than a couple of mph in WOT speed, and that might be why Carl recommended the wide spacing!
Old 01-19-2015, 12:54 PM
Well I have most of my bracket mold cut and assembled. I used 3/4" Melamine sheets to form the mold so that I could wax the surface and have few to no sticking issues. I sometimes use MDF sheeting and then line it with plain white Formica which works better for doing curved parts. I decided to make it 22" high to the top of the swim platform with a 22" set back. Not a 100% sure the motors will get a full tilt here but if they don't I will modify the rams so they will not over extend and hit. I am much more concerned with minimizing set back vs getting more tilt. If I can tilt the motors up enough to get past the hull bottom and also clear the road when on the trailer then that will be all I need. Just want to help the balance by keeping the setback short as possible with out notching the transom and loosing the factory fish boxes across the back. The flotation tank will be 60" wide to go all the way out to the start of the 3rd steps. That will leave me just enough room for trim tabs or k planes. The swim platform will be 72" wide extending 6" past each end of the floatation tub. The flotation tub will be mounted low as possible, at 2" up from the hull bottom to clear the rise of the water rolling off the back of the transom. The tub will also have a 20 degree vee on the bottom to match the second step deadrise so that it will parallel with them. This will leave just enough room under the bottom of the tub for a garboard plug set center of the transom. The vee section of the tub will be angled slightly upwards to the rear point to allow an additional 2" of clearance for the water surface. This should be enough to keep the flotation bracket from dragging the water when the boat is running with no trim.
It was fun figuring out all the angles when cutting the pieces and designing the bracket. The transom in the 25' seafari is about 12.5-13 degress just like some of the other seacraft hulls. With the transom lay back and the upwards taper of the flotation tub aft made for some complicated compound angled pieces that were a little brain racking to figure out but not so bad once it was plotted out on paper.
I made the sides of the tub section of the mold taller than needed so that when I glassed it in the top edges would not roll away from the side of the mold when the fibers curl out past the top edges. I will just cut it to height with a thin cut off wheel once popped out. The front side that will bolt to the boat will have a 4.5" notched lip inwards to allow for the swim platform front lip to lap over it and in place while maintaining a flush surface. I actually cut the last 4.5" off of the front side of the mold then used a 1/4" piece of ABS plastic to space the top strip inwards towards the rear of the mold then backed it with some scrap 3/4" ply that was scrap from the transom core. I also added a 6" wide strip of 3/4" ply to the top of the front of the mold just to hold it square. In the pics below you can see the stepped section. I will contour the corners tonight with clay and round them with my radius forming tools. Then it will be ready for waxing and layup.
Here is a few Pic's:
Cut and ready to screw together:
Attached together:
Showing the notched edge for the overlap of the swim platform:
The sketch and design...lol
Old 01-19-2015, 07:14 PM
, , , The swim platform will be 72" wide extending 6" past each end of the floatation tub. The flotation tub will be mounted low as possible, at 2" up from the hull bottom to clear the rise of the water rolling off the back of the transom. The tub will also have a 20 degree vee on the bottom to match the second step deadrise so that it will parallel with them. This will leave just enough room under the bottom of the tub for a garboard plug set center of the transom. The vee section of the tub will be angled slightly upwards to the rear point to allow an additional 2" of clearance for the water surface. This should be enough to keep the flotation bracket from dragging the water when the boat is running with no trim . . .
Good idea on minimizing setback and making a wide tub!
On the width of swim platform, you might want to consider extending it far enough past flotation tub to be able to mount a swim ladder underneath platform! Regarding angling bottom of swim platform, you're losing some flotation doing that. Looks like you're planning to mount it a bit lower than mine to gain flotation (good), so understand desire to prevent dragging in water, but might want to send a PM to Don Herman about that. The Hermco bracket is straight on bottom and longer (30"), but it doesn't drag in water when on plane, even at 12 mph. Even if it did drag temporarily coming on plane, it would act like a trim tab and provide more stern lift to help boat get up on plane, so I don't think that's a bad thing! Might look at making bottom straight with no slope but mount about 4" up from bottom, and see which design has more flotation.
Old 01-20-2015, 09:23 AM
Thanks for the insight, I can make the swim platform wider for the ladder to fit under and that might be a nice addition for the kid getting in and out of the boat (this will be out family boat). How wide of a space is needed for a telescopic ladder like you have? I was going with the 72" wide unit due to that is what my last one was on the 20' hull and I already have the top half mold built. I wanted to make it 84" wide but after looking at the rear of the boat the 72" would give me clearance for the rams for the trim tabs or the K planes that I will probably use. I have the tub so wide and the swim platform so low it doesn't leave much room for the tabs rams. I want the platform low to the water as possible and even with the low clearance model tabs I don't think I have enough vertical room to mount the top of the ram. The narrower platform will let the rams mount beside the edges and clear the platform. I don't want to cut holes in them and run them threw the swim platform or I don't want to use the Volvo tabs (they are nice but not good for my application). I have a sketch of a custom trim tab I will build if I do not get the expensive K planes that is similar to Mr BlueHerons tabs. It looks like I go with have to go with the more narrow platform and have room for the rams or I will have to make some kind of low mounting custom rams for the tabs that will mount low enough to clear if I make the platform wider. I don't mind making a new mold for the top half, but just need to figure out the details so the ladder and tabs will all fit correctly or it will not be worth doing and then it will make more since to use the 72" mold I already have.
Now about the taper on the tub, I may be worried about something that will not be a problem. I figured it may need the extra room due to me mounting the tub so low. I didn't realize the Hermco is straight outward on the vee part of his, Every bracket that I have seen other than his has had a taper up wards on the vee and more than the 2" that I used. Most taper is like 4-5" up wards. I don't want to loose the volume and had it sketched out as a straight leg but after pulling strings and taking measurements I figured it would drag unless the boat is riding very flat, level or have the tabs buried to keep the nose down. Even with the 2" up wards angle it will only allow for a minimal attack angle before it drags. I changed this last minute after reading about another guy who made one without the taper on the vee and it caused his to porpoise back and forth he clames. He said it would hit the vee and then it would make the nose dive like a tab would but then it would lift back on it and start proposing. He said the boat did not do it before the bracket but only after installing. It was mounted low also. His may of just been a balance issue mainly but it got me worried and that is my basis for adding it.
Far as what would have more flotation volume (not a math wiz) but the 2" taper vs no taper at a 2" higher mounting height would cause me to loose more volume if mounted higher even with the straight leg? The lower 2" mounting would allow the larger part of the tub to sit in the water more vs only a 1/2 of the 2" slice I am cutting off. Correct me and I may be wrong but wouldn't the lower mounting with the 2" taper yeld more volume? You got me curious now because the main thing I wanted was the most volume as possible with out any negative effects. Looking at other pics of 25' seafari's they seem to ride bow proud with the hulls planning at an angle upwards and this would greatly effect the outcome of needing the angle cut on the tub or not I am thinking? I figured to start with the water rising off the transom will rise at 1" per foot back, so that will leave little clearance at 22" back due to the water should of rise around 2" at this point letting it just scrape by with out any addition room for error and that is assuming the boat is level in the water at plane. Factor in the angle of attack the boat will ride at and that will cause the tub vee to angle down into the rise of the water leaving the transom. I might be over thinking all this but that has been on of the blind factors I have been trying to figure out. Any more incite on this would be greatly appreciated.
Old 01-20-2015, 05:14 PM
CoreyTrx CoreyTrx is offline
I like your bracket design. I made my bracket just like the Hermco's with it straight back. It doesn't angle up. Mine is a 30" set back and mounted around 3.5-4" up and it doesn't drag. It has more then enough flotation also.
Old 01-21-2015, 11:11 PM
Thanks for the insight, I can make the swim platform wider for the ladder to fit under and that might be a nice addition for the kid getting in and out of the boat (this will be out family boat). How wide of a space is needed for a telescopic ladder like you have? . . .
Now about the taper on the tub, I may be worried about something that will not be a problem. I figured it may need the extra room due to me mounting the tub so low. I didn't realize the Hermco is straight outward on the vee part of his, Every bracket that I have seen other than his has had a taper up wards on the vee and more than the 2" that I used. Most taper is like 4-5" up wards. I don't want to loose the volume and had it sketched out as a straight leg but after pulling strings and taking measurements I figured it would drag unless the boat is riding very flat, level or have the tabs buried to keep the nose down. Even with the 2" up wards angle it will only allow for a minimal attack angle before it drags. I changed this last minute after reading about another guy who made one without the taper on the vee and it caused his to porpoise back and forth he claims. He said it would hit the vee and then it would make the nose dive like a tab would but then it would lift back on it and start proposing. He said the boat did not do it before the bracket but only after installing. It was mounted low also. His may of just been a balance issue mainly but it got me worried and that is my basis for adding it.
You can buy ladders in various widths. The one I got was a Windline and needs 13" of width to install. It's a clever compact telescoping design, and works well when lowered, but the top section has to slide thru some U-shaped brackets lined with teflon so can be a bit difficult to raise and lower unless you remember to spray it down good with some silicone or super lube before you launch the boat! There may be other designs that are easier to deploy.
You should be able to lay out/compare the geometry of a flotation tub extending 30" straight back from the transom mounted about 4" above keel vs. one mounted 2" above keel and only extending back 24" to see which is closer to water. The angle/rise of water coming off transom will change depending on speed; more rise at low speed. That hull should plane at about 12 mph if it's balanced right. Maybe you could make up a piece of aluminum angle/plate to simulate dimensions of tub and try it out on your race boat to see if it's clear of water!
My experience is that porpoising occurs at higher speeds, 20 kts+. I think most boats will tend to porpoise after adding a bracket just due to the CG shift caused by moving the motor back, even if tub is clear of water, unless other stuff like console and gas tanks are shifted forward to offset the weight of motor moved aft.
Old 01-22-2015, 08:11 AM
That is a good Idea to simulate it on a running boat. The race hull has been decommissioned and is no longer under power and has be stripped bare, but I could try to get a measurement on my 20 sceptre. It has a 23" setback, only an inch more than the new bracket I'm building plus it is mounted really low so it should be similar. I used a tub on it that has about 4" of angle up around 22.5 degrees but I could add some foam to lower of the tub and temporary glue it to the bottom for a trial and see if it drags or how close I can get. I worked on it the tub last night a bit and ended up angling the bottom up slightly at 12 degrees. It is not much angle upwards but just enough to aid in matching the angle that the water will be at coming off the boat. I know the water will rise coming off the transom a little bit and I decided to lower the tub a little more and keep a slight angle to help match it up to prevent drag but still retain as much floatation as possible. I have it ready for glass so unless I see something running a trial on the 20' tomorrow that really jumps out and see a change needed I will I will be hopefully popping the tub out this weekend.
Thanks, I hope mine turns out as good as yours did!
Old 01-22-2015, 08:36 AM
cdavisdb cdavisdb is offline
Interesting project, thanks for posting.
Porpoising will an issue with the 25 hull and a bracket, because it is so sensitive to horizontal CG. You talked about a ballast tank. Particularly with bracketed OB, that is a great idea and could pretty much eliminate porpoising issues.
Old 01-29-2015, 01:31 PM
Work has kept me from finishing the bracket but I have still have been making progress. I had gotten the clay filets in the corners and rounded them off with my filet tool. I started out with some clay my coworker gave me (she makes clay art) but that was not the right stuff for the job. It dried out way too fast and shrunk. The shrinkage caused it to crack up so I had to remove it and then start over with the right stuff the second time. I got some modeling clay that was listed as shrink free and the package said that it would not harden either. It was much more playable and went in much more smoothly. It was also shaped in little sticks so it fit in the corners perfect for making radiuses. Once I got this done I waxed it a few more times. Over all I waxed the mold a total of 7 or 8 times letting it dry 15 minutes and removing it each time with a special cloth made for buffing out molds with wax (forgot what the cloth is called). I got the gel coat sprayed in with my cup gun. I sprayed 4-5 mils then let it kick slightly then did a second coat of 3-4 more. I didn't thin the gel at all so I could of sprayed it in one thick coat but I was worried about it sagging on the sides. Cold as it was it came out slow and thick. The cup gun works well for mold like this due to it gets in the corners good with out hurting the filets. After this, while still slightly tacky, I laid 2" strips of csm in the corners then a 4" wider strip of csm in the corners. I had all the cloth pre-cut so it went well laying it in at one time before it kicked off. I laid all the sides with 2 layers of csm and overlapped the sections to prevent seams. Once it was all in I rolled all the air out as well as possible and got the csm laying so that it looked like one continuous layup. I used the csm as a skim coat to help prevent print threw of the 17oz biaxel. I have several layers of 1708 and 1700 to lay in also but haven't had a chance to get that far yet. All the csm has fully cured now so I will have to scuff it up with some 80 grit to get a good bite for the new resin to bond too when I lay it in. I wanted to keep it all green on green but work would not let that happen. I hope to get the rest in tonight as well as bed the rear motor mount core in place too.
Clay filets in:
The bad clay I used and had to remove:
The mold after White Gel coat was sprayed:
The cup gun I spray gel with:
