Old 01-19-2015, 12:41 PM
bibijawa bibijawa is offline
Default wet foam in stringers
After grinding the inner sides of the stringers to prepare the area for the new fuel tank slats I'm going to glass in, I noticed water leaking out of a couple of areas where the woven roving was delaminating. My stringers apparently have wet foam. Since I'm not removing the deck I won't have access to the stringer tops. Will it be structurally safe to remove the sides of the stringers to remove the foam then glass those same skins back on?
Old 01-19-2015, 01:18 PM
I might would try to cut out some oval or square holes in the sides then patch over them. if you cut the sides out you will loose the structure and could warp the hull. If you cut the holes you can remove it threw them by digging in out and the material left will keep the shape. Then once done glass over the holes and cut small ones at the top edges to refill the pourable foam threw.
Here is what I am talking about:
Old 01-19-2015, 07:03 PM
FAS FAS is offline
frizz, you're a smart man,good way to fix that,support, cut ,fix and reglass...really like your illustrations...
Old 01-20-2015, 10:35 AM
shine shine is offline
Moderator
I think it might be less work overall if you remove the sole and do it all from the top.
Old 01-20-2015, 11:39 AM
Can this wet foam cause hull blisters? I don't know how long this foam has been soaked, but most likely it's been wet for years.
Old 01-20-2015, 11:51 AM
Most hull blisters are from water coming in from the outside and getting in the fibers in the glass and puckering out the gel coat causing the gel coat to blister. I could do it from the inside out I guess but the main troubles with wet foam is the extra weight that you are carrying in the hull. Water logged foam is heavy!
Old 01-20-2015, 02:42 PM
martin martin is offline
I would hàve to agree with shine , but then again after seeing my build I definitely made a lot more work for myself..lol
Old 01-20-2015, 05:35 PM
Shine dose have a good point,
Old 01-20-2015, 06:13 PM
Looks like a lot more work than I thought. Maybe I'll just drill some holes along the bottom and let the excess drain out. I really don't want to remove the deck as it is in good condition and I'm already tight on work space. If it is really fully soaked how many extra pounds can it be? 200 -400?
Old 01-20-2015, 09:23 PM
FAS FAS is offline
If you don't need to replace the decks,and its a lot bigger job that one would think,figure out a way to get that stuff out from the sides.what model and year is the boat?you most definitely could cut some sides out enough to remove the crap ,in say ,3 different spaces per 6 feet.leave about 8" original,solid glass there,, between the cutouts.temporary glass each space back up,when you're cleaned out and move on down the stringers.once its all dry, level everything and reglass the sides ,leaving several 3inch or so pouring spots, up high to pour in expandable foam to refill everything.glass those spots up when you got everything filled.it would be important NOT to cut all the way to the hull bottom.leave at least 4" or so per 2' ,to hold original shape
