Old 03-26-2015, 10:15 AM
Bryan A. Bryan A. is offline
Default Etec 200 on a 20SF
Is anyone running a 200 Etec on a 20 SF?
I am rebuilding mine right now, already have a 25" transom in, no bracket.
Re doing deck right now.
Is this motor to heavy to self bail if the deck is raised 1"? Assume batteries in console, tanks slid forward, etc.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 03-26-2015, 12:19 PM
That sounds awesome. Hope it works out
Old 03-26-2015, 08:04 PM
bgreene bgreene is offline
200 standard or 200 HO ?
Old 03-26-2015, 09:53 PM
The standard. 60 degree block. Apparently it's lighter about 430 lbs.
I had a 175 Johnson on it with the 20" transom. I think I would be fine with the transom raised and all the wet foam removed.
Thoughts?
Parker 2530 DVEC
Old 03-27-2015, 04:36 AM
Sounds like a good plan to me.
Old 03-27-2015, 07:18 AM
These are the specs on the old 1986 175, and it was on a 20" transom.
Horsepower
175
Cylinders
6
Start Type
Electric
Dry Weight
396
Power Tilt and Trim
Yes
Parker 2530 DVEC
Old 03-27-2015, 08:20 AM
I have 435 lb with main engine and kicker on a 20MA with batteries forward and tank forward. I hear that the 75 MA has a higher deck than an earlier SF? It only just self bails. It does, but not hugely. My tank is far forward- under the console and it is only 20 gallons. Batteries are in the console. So if your deck is raised an inch, you might be ok.
Old 03-27-2015, 10:21 AM
Chaser Chaser is offline
From my recent experience if you rebuild the boat using light materials and modern building techniques you can put as heavy an outboard on the transom as you like. My boat now floats on its original lines with a 485# Honda. Decks are dry even with two people standing all the way in the back of the cockpit. Deck is only 1/2" higher than original.
My new tank is 1/4 the weight of original. New foam core decks are 1/4 the weight of original. The old cockpit sole was ridiculously heavy plywood with way too much glass. Throw it out and use 1/2" foam and don't worry about the weight of the outboard.
Old 03-27-2015, 11:01 PM
Andrew Hill Andrew Hill is offline
If I had to guess I'd raise the floor a hare more... you are doing all the work anyway. I'm running a 200 etec small block on my 20 SF w/ 24" bracket. I went between 3 & 4" up with the floor, glad I did...
Old 03-28-2015, 08:08 AM
On this page is my scumline at rest- there was a thread on CG location on the 20 MA a while back.
http://www.classicseacraft.com/commu...766#post233766
