Old 03-31-2015, 07:53 PM
abl1111 abl1111 is offline
Default Trailer Tires ?
(2) of my (4) old trailer tires are splitting as they sit the cold winter. They are ST205/75R14,
(4) ply. All different makes.
One of the newer tires is a D14 - it sits slightly higher than the others - it was replaced 12 years ago !
I do not trailer much - at all. Usually it's 1 mile to the ramp - the trailer will sit for (7) months and then 1 mile home again, where the boat will sit for the off season. I've done this for 12 years. The trailer is a mid 80's, Florida Rocket trailer - in NY. So, long distance usage is not an option. It totally meets my needs.
Note: to get the trailer in position along my house for winter storage, the tires do get torqued a bit and left that way.
What are good tires for this type of use ?
Old 03-31-2015, 08:50 PM
I have heard ply tires are best if a trailer sits weighted for long periods of time as the steel belts in radial tires will rust from supporting the weight and blowout down the road
Old 03-31-2015, 09:16 PM
"I do not trailer much - at all. Usually it's 1 mile to the ramp"
Simple, go to Wal-Mart and buy the cheapest trailer tires you can. On the other hand if you are towing long distances spend the extra money and buy Maxxis 8800.
Old 04-01-2015, 08:48 AM
Sage advice...
Same thing goes with trailer springs. I only dip my trailer 2 or 3 times a year in salt water. Bring it home and rinse throughly. 3-4 years later need to replace the springs.
I have sprayed, oiled, painted, Prayed to the Seacraft Gods...no avail...3 years and replace.
Old 04-01-2015, 01:04 PM
Carlisle USA Trail 205/75D14/6 ply Boat Trailer Tire*is a decent choice. Wallyword sells them.
Old 04-01-2015, 01:17 PM
I bought a set of 4 $28 futura 13" radial car tires from pepboys in FL 10 years ago. I drove 3300 miles cross country with the trailer in 2004 . . . all over CA . . . back cross country in 2008. I gave the trailer to my brother in 2010, he's still using it with the same tires.
I had bought another Venture trailer that was new in 2011/2 for my 23. 2 of the 4 loadstar tires blew out last season on the highway and the other 2 have splits around the tread
If you are only going to drive 1 mile and don't care about a flat on the road . . . you'll be fine. Just back off the nuts and put antisize on the studs, so when you get a flat . . . you can change the tire.
If you get new tires . . . your can always block up the trailer in the winter time.
Old 04-05-2015, 11:17 PM
I ran car tires on my trailers for years !!!! did some homework on this before i bought the new set last year... and bought 4 new westlake tires off ebay ... but in your case i would go with the cheaest car tire i could find due to the distance and speed traveled... even better would be used
RUSTY PARKER
Old 04-06-2015, 11:06 AM
Thanks all - I bought (2) new tires from a local guy - some Chinese brand that will suit my needs. I did go with 6 ply "D" as opposed to "R" tires based on them sitting so long and the short travel time. One galvanized rim looks like 'sheet' - the back heavily rusted… I'll try to find a used one of those as much of the metal is gone… Thanks again.
Old 04-07-2015, 01:46 AM
if its a standard rim 5lug x 4 1/4" .. ford ranger aluminum with the centers releived work great ... i used a bastard file ... it removes more metal than a side grinder in less time .. i bought 6 aluminum ranger wheels for 125 bucks off craigslist...
RUSTY PARKER
Old 04-07-2015, 12:00 PM
Thanks for rim info - I'm going to grab (2) rims as (1) is painted and rusting badly and the other galv'y is rusting near hub ...
