Old 04-23-2015, 12:14 PM
I'd forgot you had the bracket, regardless very impressive numbers. I'll guess your motor can still go up a notch or 2. Nice details on report. Were you able to reach max rpm target?
Old 04-23-2015, 02:23 PM
72potter20 72potter20 is offline
Max rpm for this engine is 6k. Best I could manage was 5600. I'm not the type of guy to take an engine to its max rpm anyway
once I raise the engine up a hole, do you think the rpm will increase at wot?
Anyone in st. Pete with a cherry picker?
Old 04-24-2015, 01:06 PM
Yeah, you should see a bit more rpm if you raise it a notch or 2.
Hopefully you gain as much as 400 rpm so the motor is able to reach max rpms with your regular load. Look forward to more news.
Old 04-25-2015, 05:19 PM
Had it out for 2 hours today. I couldn't set any speed records as it was to rough and windy. I did get some cruise numbers though
On plane in about 2 - 2.5 seconds. This isn't accurate I found it hard to time as with the motor trimmed down to start, and trimming up with throttle the boat stays very flat in the water, hardly any bow rise.
On plane at 3k rpm, 15 mph
3200 rpm - 22.8mph trimmed out
3500 rpm - 24 mph
4000 rpm - 29 mph
4500 rpm - 34 mph
5000 rpm - 39.7 mph
5200 rpm - 41.9 mph
It starts to chine walk going 40 into a headwind And a little chop gets it going
That's as fast as i could take it with conditions. I'm impressed on how it handled it though.
The boat has no tabs by the way. I don't think I'll need them though as I can control it with trim
No fuel numbers as i haven't networked the motor to my a67 through the nmea2000 port yet.
Old 04-25-2015, 06:03 PM
Btw i just noticed there is no anode trim tab behind the prop. there is an anode, just no tab. The only time I've seen this is on twin counter rotating setups
Only lists on plane I've noticed are on Cross winds, but may be because of no tab? I'll have to contact mercury on Monday
Old 04-25-2015, 07:37 PM
tautog_33 tautog_33 is offline
Those are good numbers, I am getting similar performance out of my 1994 mercury 150 2.0l with alot more fuel burn of course. This new mercury 115 CT will be on the top of my list when I re power. Thanks for sharing!!
Old 04-26-2015, 09:40 PM
It sounds like this motor has power aplenty and I cant help but think that properly positioned torque tab would benefit tracking. They are surprisingly sensitive.
Old 05-09-2015, 01:53 PM
Hit 46.1 today just me and 39 gallons of gas and some tackle and fishing Rods. Feels good being on the water on a 43 year old boat. Gets a lots of compliments that's for sure
