Old 04-07-2016, 09:05 AM
I feel your pain. Replacing mine currently and the hose is as hard a brick. Not much flexing.
Old 04-07-2016, 09:24 AM
if you can reach down to the corner were you have the deck and it makes that hard 90 degree bend I used WAX paper to shield the inside of the bend felt like if I got too much soap on the fuel line it might make it hard to pull on when i got it close to the tank . the wax paper made all the difference for me to get it around as there is no real radius to pull around.
Old 04-07-2016, 11:20 AM
I can reach that far now. Thanks for the tip.
The hose is petrified rock. Can't believe it hasn't
crumbled/failed.
Old 04-07-2016, 12:09 PM
If I remember when I changed mine (23') the fill and vent were wired together and the hose has wire as a stiffener.
Old 04-07-2016, 03:33 PM
Hose has wire reinforcement
New tank came w brass pickup elbow and copper p u
Tubes. Copper???
Use old aluminum pu's ?
They are I excellent shape.
Old 04-07-2016, 04:18 PM
Sandy - my 88 18SF had its tank replaced. I may still have the receipt… It was around $1500. There was a pie plate access right in front of the fill hose. I had no idea how hard those tracker tank hoses were to get out!
Old 04-07-2016, 05:15 PM
Yeah Danny, the pie plate is necessary.
Old 04-07-2016, 05:45 PM
pelican pelican is offline
Tubes. Copper???
that's not good...
gonna cause a galvanic reaction....
bronze fitting - they need to be separated from aluminum with a stainless insert - or,use aluminum fittings...
not sure where you got that tank manufactured,but,they should known better than that...
Old 04-07-2016, 06:14 PM
Originally Posted by pelican View Post
that's not good...
Tell me about it
Old 04-07-2016, 07:18 PM
that's not good...
Elbows are brass. Today class we are going to make batteries.
Lead solder
Brass
Copper
And aluminum.
And these folks do this for a living?
RDS built the original tank but had a 2 month wait...
Sunshine is 6 wks.
