Old 05-28-2016, 01:20 PM
Drippin Wett Drippin Wett is offline
Default Trailer rash repair
Hey y'all. I am looking for suggestions and materials to repair some trailer rash on my 06 SeaCraft. My biggest fear is water getting in and separating the glass. I have added forward bunks to the trailer in hopes this will never happen again. It's not hitting now, it was like this when I got the boat.
I don't have a lot of fiberglass experience and will pay for repairs if necessary, but really enjoy the "do it yourself projects " and learning. The boat shop down the road didn't want to repair it; they wanted to glue a keel guard on it. While I know they have their place, I'm not wild about them. I appreciate any advice. Thanks!
Old 05-28-2016, 05:40 PM
I would dump that forward V/PVC guide and go with a pair of forward bunks. You can raise them enough to get that keel off those forward cross members. Added small 1" starboard pieces adhered to those cross members for protection.
Also notice I made a custom "V" Center Transom Rest Bunk that forces the stern to settle in perfectly each time.
any questions PM me
Old 05-28-2016, 06:04 PM
Default Trailer Rash Avoidance
Thanks, Capt Chuck. I love my Hitchhiker tandem axle that I bought in 1979 because it avoids the trailer rash than I was getting with the previous trailer. However, I like your idea of the forward bunks as they would start guiding the bow sooner. Things go well unless my driver is coming on too hot and tries reverse to slow down; although the boat stays within the perimeter of the trailer, it goes misaligned at the bow requiring me to grab it to straighten it out. I will consider a modification.
Old 05-28-2016, 06:30 PM
any questions PM me
Thanks for the response. I have already added forward bunks and she is plenty free and clear of the cross supports now. Those are old pictures before the trailer mod. The forward bunks I have now block me from being able to get a picture of the repairs I want to make on the boat.
Old 05-31-2016, 10:54 AM
Soooo.... back to the question of the repair 'cuz I got the same issue. I did the trailer upgrades mentioned last year so I stopped the cause. Just need to repair and interested in the suggestions.
Old 05-31-2016, 11:59 AM
Bobby at G-Crafts in Awendaw did my glass and I've been happy.
Old 06-03-2016, 02:13 AM
Tiny Tiny is offline
Might be ugly but it doesn't look that deep, or structural. I've seen a few of the older ones where it's worn straight through to the keelson. At that point you have to dry them out good then grind back some and lay on some heavy roving layered up. It's easiest to do building it backwards...meaning take a large piece and wet it out, then a piece an inch or so smaller in diameter, then another an inch or so smaller, so it winds up looking like a hill on a topographical map...then apply the whole patch to the hull. Maybe 4-6 layers. Then some gelcoat then go fishing. But what do I know my boats 40 years old ;-). Pretty she aint, but she runs out well.
Old 06-06-2016, 08:47 AM
Thanks for the response Tiny. I think I'm going to wait til the winter and try your approach. Would you just buy a repair kit? Or would you think I would be better off resourcing a particular fiberglass and resin?
Old 06-06-2016, 11:08 AM
It appears not structual as mentioned above. Therefore, I would try this simple inexpensive repair first.
Try this 2-part Epoxy @ 50/50 mix.
http://fiberglasssupplydepot.com/Fas...-Compound.html
Clean the area first with acetone. Use the mix and spread with putty knife. It hardens and sands like your gel coat / fiberglass. Most likely, you will need a 2ND application after the first sanding to get it smooth. Use 150 grit then 220 then 400. Dries white and can be topped off with paint. Easier than laying glass upside down
Old 06-10-2016, 08:02 PM
fas-stone fasco is awesome stuff! For sure. I just love that stuff.
