  #31
Old 10-06-2016, 04:16 AM
natecert natecert is offline
Actually call Tony Perez
Sunrise tanks in Venice.
Great guy excellent work and priced fair...his Dad use to own Sunshine in Miami.
941-412-3500
Ryan at Fiberlay is the man...sometimes he gets stressed, but he knows the products well.
I like the idea of Sunshine Tanks because I could bring the boat to them and go over options,
Yea Ryan was stressed out but always was looking out for what I needed. What I had to repeat several times was the need for light weight product. Trying to loose weight on the boat. Next time I will make the order and call at 8 am to go over every thing and take delivery at their store the next day.
Old 10-06-2016, 04:18 AM
V part II
Also, on THT there is a group buy going on for fuel bladders. Why not water? Just sayin.
Will look into this liquid is liquid right?
Old 10-06-2016, 04:26 AM
#30 Report Post Old Yesterday, 04:04 PM
cdavisdb
I use an 8 hp Yamaha 4 cycle Hi Thrust model. Its geared and proped for low speed, high torque, kicker type uses. Works great on a 25 Seafari, much better than my old 15 hp Evinrude. The extra torque gives you the ability to push through moderate wind and chop with little loss of speed.
What type of tie bar do you use? A pull start is ok by me and setting the throttle manually is ok as well. What about Nissan or Tohatsu?
Old 10-06-2016, 07:02 AM
Kicker:
I was at IBEX and saw Honda's new line of small 4 stokes. The 8 hp kicker was small enough to store anywhere and if I needed one I would incorporate a storage area just for it and only bring it out if necessary.
Old 10-07-2016, 07:20 AM
__________________________________________________ _____________
Ken, that is an option but in 4+ sea conditions it may not be an option then again if you were to set the hook or deploy a drift sock it could work. Will consider the option.
Ed
Old 10-09-2016, 02:59 AM
Slow going but at least got the glass rack done. Those rolls are heavy.
Old 10-09-2016, 03:49 PM
cdavisdb cdavisdb is offline
no tie bar. It would be very nice, but the idea doesn't work with the drive/platform/engine mount that I have.
I haven't really needed it so far. The kicker can be set for any thrust direction and locked in that position. From there I can steer the boat with the 1/0 drive. This works fine when its reasonably calm, not sure how it would work if it was really nasty. If I had to steer from the stern, it quick and very positive. The kicker controls the boat real well.
Old 10-10-2016, 03:17 AM
If the kicker can be locked into a straight position then I believe your correct about steering with the main motor.
I have the next three weeks to skin coat 11 boards and some final tweaks to the lay up table. Its just is not as rigid as I want it to be. My thought is the final product will only be as good as the lay up table.
Made it in two pieces 22" wide and 1/2 thick with 1/2 X 3/16 aluminum stock on the edge. Have 2 saw horses and will try adding a two more.
Quick question, can I use peel ply over the lay up and use a roller to squeeze out unneeded resin?
Old 10-11-2016, 07:23 AM
I know you already have your table made up...but what I used was a big melamine board table...easy to clean, and when it got gross I just flipped it over and used the other side. I think I went through 2 0r 3 during my build.
Old 10-11-2016, 12:21 PM
FLexpat FLexpat is offline
That's what I do before I vac bag it. Make sure you use one of the ribbed aluminum glass rollers though. Peel ply also prevents blush on your part if it is an epoxy layup.
