Old 09-03-2017, 01:30 PM
Opening out. Numerous reasons previously noted, and harder for hoodlums to open by kicking in. I stuck with the hinge on the right. I like the magnetic open position latch that Vezo described. Removable hinges is an interesting idea.
Old 09-03-2017, 10:24 PM
Default Cabin Door Magnet
I like Vezo's magnet idea too. Have one on a bedroom door but would want a stubbier one on the Seafari
Hey Michael where did you get it?
Old 09-04-2017, 08:07 AM
The only problem with using a magnet is that any metal with enough steel in it to be magnetic will rust! Maybe ok in a fresh water area, but not good in the salt! I've used a small nylon cabinet latch with a ball attached to door and a tubular catch screwed to deck at edge of step down. Has worked great for over 30 years!
Old 09-04-2017, 08:52 AM
Unfortunately it was broken during some mods by my mechanic, soon to be family, but knows where to get the replacement. I will have to get back to you.
Vezo.
Old 09-04-2017, 02:32 PM
Good point on the magnet Denny, an adequate nylon ball catch is a good idea. I have original hook, but not the best for quick response if surfin Seafari alone. Rust and breakage = no es bueno. Maybe something like this?
http://www.tashcosystems.com.au/uplo...Ball_Catch.jpg
Old 09-05-2017, 02:30 PM
Gents:
Nice discussion on the magnet/ball catch latching mechanism. That has been a very good addition to the topic, and I think that will be my hold open system instead of a hook.
In my original post, I included a picture of the door - but it is not original to the Seafari. I scrounged it from a barn from a guy that had parted out a bunch of old boats. From the hardware I took off it, I believe it is at least from the 30's or 40's and mahogany, from a classic runabout.
I sanded it down this weekend, but have not added the finish yet - and the grain is nice and tight, clear and has a lot of character. I ordered hinges that lift off for convenience. I can install it either direction, hinge left or right, but am leaning towards left because the door is already drilled for latch on the right. It is designed with an outer screen and folding inner panel for ventilation. Here are a couple of shots of the inside of it before sanding.
John
Old 09-05-2017, 11:55 PM
Now that's some cool old stuff!!! Now I understand the upper portion screened. Very cool. Keep sanding and then when you thought finished, rub a wet cloth over the surface. Instantly you will view possible true finish, simultaneously raising grain enough for a quick hand sand again with 220 or higher! You have a shit ton of potential with that door.
Michael.
Old 09-06-2017, 02:22 PM
Thanks, Michael - I will try to post some next stage photos later in the week after some of the finish goes on. In the meantime, dodge Irma!
John
Old 09-20-2017, 12:02 AM
Aaronfab Aaronfab is offline
Default Poll Seafari door opening in or out
Anyone have the lub for the door hinge leaking onto the outside part of the car. Meaning black goo around where the fender meets the door?
Old 09-20-2017, 11:53 AM
I am not sure what you are referring to - do you have a photo?
