Old 10-18-2017, 11:26 PM
JBASS02 JBASS02 is offline
Default '72 Super Fish 20' Rebuild
Thought I should start my rebuild thread. Bought the boat from a guy who had it for the last 20 years out of Chico, CA. He said the owner of a local dive shop owned it before him. As you can see from the photos the boat had blue carpet throughout, lots of spider cracks, two soft spots on the deck, and a transom with an unknown degree of rot.
Old 10-18-2017, 11:45 PM
I ripped out the carpet the first day, and have now started to remove the carpet glue. I found some carpet glue remover at Home Depot that does an OK job softening, but it's still a pain. Lightly wire brushing the glue in several directions seem to work. I sold the motor today and am hoping to cut into the transom on Sunday.
My game plan for the project is to Coosa the transom from the exterior, patch and repair the big problems with the deck and cleanup the console this winter. Then next winter pull the liner and do the floors.
Old 10-18-2017, 11:54 PM
Oops, already messed up. It's a SF not a Master. Any chance a mod could change the title?
Old 10-19-2017, 07:01 AM
Title looks right to me. Good luck on the rebuild!
Old 10-19-2017, 07:02 AM
Duhh, now I see what ur talking about.
Old 10-19-2017, 09:20 AM
Dogbomb Dogbomb is offline
Congratulates! Should be a great project.
Good to see another California SeaCraft!
Old 10-20-2017, 06:54 AM
Done
Old 10-23-2017, 10:47 AM
I've been getting everything in order to begin tearing into the transom. Last week I sold the engine, picked up a used smaller trailer so the boat will fit in my garage and cut into the transom... First unexpected problem, it appears that someone has attempted to repair part of the transom in the past. Some sections have what looks to be a pored in foam(Seacast maybe?) while other areas are rotten plywood. The problem is that the glass is really bonded to the areas with the foam. I'm afraid the glass is going to break rather than separate. Does anyone have any recommendations for a method to remove the glass?
Old 10-23-2017, 03:43 PM
7"grinder with 36 grit sand paper on a backing wheel...
oh yea a few dust mask, your going to need them
Old 11-06-2017, 11:31 AM
Update- I was able to remove the transom fiberglass in one piece by wedging long shims between the two sheets of plywood then taking a oscillating saw and cutting the outer sheet of plywood. The area I thought was poured in foam turned out to be shoddy thickened epoxy work. Is this typical? The fiberglass thins and is replaced with epoxy as it goes to the outer edges of the hull (see photos). There are many large voids in the epoxy filler I'm assuming I need to remove as much of this epoxy as possible and replace it with fiberglass? I'm having trouble figuring out how to remove the transom u-bolts? it's too tight to get a socket or wrench inside to remove the nut. Any recommendations? I may just cut them out and relocate new ones lower on the transom?
